You can try the D4 feature,turn the vehicle/ignition off,then press the power button on the wireless.On the D4 it will give you 10 mins or so of music before shutting down,less if it needs to go into power save mode.
It may work on a D3.
Andrew
 Fossicker
						Fossicker
						 Disable door chimes
 Disable door chimes
		How can I disable the door chimes when the door is open and the key on accessories setting ( listening to the radio ).
This relates to a 2008 d3
I know somebody knows, please share.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
 Fossicker
						Fossicker
						Thanks Andrew for that suggestion, but does not appear to be applicable to the D3
Does the radio not play without the key in the slot and the ignition on?
In our Freelander 2 you can turn the radio on without the key in at all & no ignition, just press the knob and it plays...
2009 Range Rover Sport 3.6L TDV8
2017 Jaguar XE R-Sport
Supercharged Jags XKR & XJR 4.2L S/C
Old Jaguar Australia - www.facebook.com/oldjaguarau
Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
 Fossicker
						Fossicker
						You are correct, I found out today while having a play that indeed I can play the radio without the key in the ignition.
I don't know if it will time out but won't be a problem as I will just turn it back on
I would still like to know if I can disable the chimes still
Les
Cheers, Dale
'The D3' - 2006 TDV6 HSE
Previously Enjoyed:
2000 D2 Td5 - plus!
I can play the radio on my D3 without the key in the ignition - just press the "on" button on the radio and on it comes. As LandyAndy states it will turn off after a set period of time - just press the "on" button again. It will lock out when the battery voltage falls to a pre-set level and the display will tell you so.
Handy for the drive-in cinema so you can listen to the radio without the dashboard lit up like the bridge of the starship Enterprise - but sadly that was a dream because there aren't any drive-ins out my way any longer - Matti
My old man has a Ford Ranger, it has a traditional key ignition, and also did the annoying beeps if you opened the door with the key in.
Turns out there is a microswitch in the ignition to detect the key, we unplugged it and the beeps stopped, but everything else worked fine.
I doubt it will be so simple with a Land Rover though...
Ah now, this is interesting...
Yesterday I was working on a Jaguar XF and there was an option in the CCF of "key-in warning chimes" and it could be selected as enable/disable.
Might be the same function available in the Disco. But it may not be possible to change with a Nanocom, only SDD...
I thought it was actually an ADR,must chime with key in ignition,engine off, and drivers door open.
