4HP22 vs 4HP24 i think
Not talking about the bloke behind the wheel here guys.
I think the auto trans is different from memory. Thinking about buying a 4.0 and getting my hands on a 4.6 to drop in. Obviously if the auto is different then it would be an extra cost.
Too hard basket?????????
Current Cars:
2013 E3 Maloo, 350kw
2008 RRS, TDV8
1995 VS Clubsport
Previous Cars:
2008 ML63, V8
2002 VY SS Ute, 300kw
2002 Disco 2, LS1 conversion
On a p38a it should swap straight over, assuming its of similar vintage.
Eevo is right, 4.0 has the 22 and the 4.6 has the 24
Sent from my HTC One using AULRO mobile app
Also a different torque converter if I recall correctly.
And is it possible to just swap in 4.6 to a 4.0 car if an engine swap is needed particularly 99-01 models?
4hp24 is the stronger of the two, the 4hp22 will hold the 4.6 in normal driving but if you are looking for power upgrades or a tow vehicle the 4hp24 is stronger, the earlier models have a bigger torque converter (much bigger actually )
Might be worth getting a gearbox to go with the engine
Thanks guys. thought they were different.
isnt the 24 longer?
'97 to '07. sold.![]()
