Greetings mango!
The 1994 models aren't too bad, the bottom years were 1995/1996 (I know what I'm talking of!). Most of the obvious bugs should have been sorted out by the previous owner(s). You did not mention if it's an auto or a manual, if it's a manual check for clonks in the transmission when changing gears, especially from reverse to first or when driving off. The splines on the mainshaft can wear out and then it becomes an expensive rebuild... The fault does not become apparent on all cars but be aware of it. Other problems apart from the ones already mentioned by others include electric problems (not too many gimmicks on your car, though) and water leaks (not really a problem in Oz :wink: ).
Oil leaks are a standard feature of your Landrover, so don't worry as long as it's not getting excessive!
And welcome to AULRO, of course!
Johannes
There are people who spend all weekend cleaning the car.
And there are people who drive Discovery.
