Results 1 to 9 of 9
Thread: Hi Idle
    Feb 2013
    Ballarat,Vic,Aus
    Hi Idle
    OK, so I've buggered up the '92 3.9's idle agian
    It always idled very, very low when it was warm. so low it would miss and carry on (but amazingly not illuminate the oil pressure light ... I think the engine itself is a really good one.... with not a huge amount of milage on it). I found the idle adjustment screw was bottomed out so I wound it out about 5 full turns and ended up with a perfect idle under all conditions. Sometimes it would idle very high ... throw it into neutral for 4seconds and the idle stepper motor would drag the idle back down to a rock solid 800rpm.
    So how did I bugger it ?? I fitted a 2nd battery in there and cut the trumpet off the end of the air cleaner. Without this there the engine can't control it's idle and screams away at 1200 -> 1800rpm depended on temperature and which way the wind is blowing. If you stick 2 fingers over the air cleaner inlet so there's some inlet restriction, the idle drops way down and the stepper motor corrects it.
    So how did you guys that fitted 2nd batteries fix this ?? I'm guessing I have to weld the inlet trumpet back onto the air cleaner ... but at an angle. so it clears the battery.
    BTW: It seems to go a lot harder, and have a far noisier ( nicer ) inlet sound.
    seeya,
    Shane L.
    PS: I reckon I know why the idle was to low as well..... Well the engine is a replacement out of a disco .... I bet they swapped a "long" motor into it with the inlet manifold intact ... I also bet the trumpet was cut off the discos air cleaner, so the idle had been screwed down as low as possible.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Crafers West South Australia
    Not sure I've noticed any difference in idle speed between trumpet off and on, unless its been on LPG and you're altering the mixture thereby. You can of course cut off the flare off the trumpet and install that straight into the lid, a bit of silicone and pop rivetting should do it.
    Feb 2013
    Ballarat,Vic,Aus
    The LPG bit did occur to me, so I flicked it over to petrol and found the same thing I guess it's possible the idle stepper motor has happened to die at the same time as I've been mucking around. The thing is though .......... The idle plummets back to normal levels with just a small portion of the intake covered.
    Weird right? I bet the idle circuit needs a slight intake restriction to work.
    I fitted a new air cleaner at the same time .... I guess I should try re-fitting old one and see if it's restricted enough to allow it to idle
    BTW: That an absolutely HUGE intake restriction. I wonder what the reason for it is. It sure does seem to go better without it.
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    If there's a significant air leak downstream of the MAF a tiny change in restriction would affect the air flow reading to the ECU, changing its idea on idle control.
    Avoca Beach
    The trumpet has nothing to do with the idle on petrol as it is only a silencer.
    The throttle blade provides the restriction.
    You have made an air leak.
    Regards Philip A
    Feb 2013
    Ballarat,Vic,Aus
    Regards Philip A
    That's what I thought too.... I'll take another look. Possibly the accordion tube has split in a place I can't see. It's very strange just putting a couple of fingers over the inlet to provide even the smallest hint of restriction cause the idle to drop back and work correctly.
    seeya
    Shane L.
    Proper cars--
    Modern Junk:
    Avoca Beach
    Have you cleaned up around the throttle blade and outlet for the engine ventilation.
    You should also check that the small pipe that leads from the T piece into the plenum has not split , or the t piece hasn't broken.
    Your leak will be AFTER the throttle blade.
    Maybe the bypass which you screwed out was partially blocked or the stepper is sticking.
    You should set the Kerb idle to about 550RPM by blocking off the outlet from the throttle body to the stepper ( and the stepper inlet) and screwing the bypass in and out AFTER you have cleaned the throttle blade and surrounds.
    The stepper should then automatically control the idle to about 700RPM. If not then new stepper.
    Regards Philip A
    Feb 2013
    Ballarat,Vic,Aus
    I did pull the stepper motor crankcase breather system apart and check it all about 6months ago ... It all worked and was nice and clean.... This all worked perfectly ... until I cut that air cleaner trumpet off. I will check it all again as soon as I get a chance I can't say I'm suprised, that inlet trumpet will be there for a reason. Surely it just can't be to dampen the inlet sound
    Mechanics bugger stuff up just as well as I do too. A mate dropped of his old car with me a week or so back... I started it up and it would barely run when cold and was lumpy as hell. When I popped the bonnet and checked I felt like headbutting a brick wall. All the crankcase recirculatoin has been messed with. It's all been bodged together with hoses and joiners ... I bet they have bypassed the auxilary air valve too ... that's why it wouldn't run when cold. I just don't understand WTF any mechanic with half a brain would do this. The factory plastic joiners in the crankase recirculation setup has metering orifices in them... ie: they close down to about 2mm from the 15cm hose to restrict amount of intake suction when the throttle is closed. Why ... just ... why I'm sure he paid a lot of money to a mechanic to make this mess.
    Back to the Rangie. The brake controller is hooked up, I fitted two of those temperature controllers to the thing. One to the trans cooler outlet, and one to the top radiator hose ... As close too the factory sender/housing engine side as possible.
    http://www.aulro.com/afvb/discovery-...larm-39-a.html
    I was expecting it not to show much useful until the engine hit about 80degrees and the thermostat opened. Guess how useful the factory temperature gauge is With the coolant at 30degrees... the factory gauge is dead center .... the damn thermostat is fully open at 50degrees (the engine won't get any hotter than this ... yes I think the new gauge is accurate as I can hang onto the top hose and it doesn't come close to burning me). At 50degree the dash gauge shows still dead center. If I turn the engine off for 5minutes and let some heat soak increase the coolant temperatue in the block ... when I restart the coolant temperature is 75 degrees..... The dash gauge is still dead center. As soon as you start the motor and the coolant circulates it plummets back to 50degrees.
    So the dash gauge is absolutely useless and tells lies. I know it shows the same reading for the 30->75 degree coolant range.... it wouldn't suprise me if at 100degrees it still showed "normal" --- dead center of the gauge... and the thermostat is either no good, stuck open or missing from this engine.
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Avoca Beach
    It does.
    Regards Philip A
