Results 1 to 10 of 11
Thread: Front swivel now ???? :(
    Aug 2012
    Tewantin (NOOSA area)
    Hi Guys
    Tracta joint output shaft as pictured running through the stub axle.
    There is a bronze??? bush shown. "Bush for driving shaft" P/N 217354.
    Output shaft and bush fit like the proverbial in seaboot,[never mind thou think fractions] and I cannot find any reference in my 48-58 workshop manual (mind you it doesn't have Tracta Joints either).
    Is this supposed to be a nice running fit? (I notice that for a plain bearing it has not lube groove) Do I need to go get or manufacture new bushes?
    Rick F
    Sep 2011
    Albany WA
    Hi Rick,
    Yes there should be a bush in there with tracta joints. I got a brass bush from our local bearing shop, cut it to length pressed it in the axel stub and machined the inside to suit the axel allowing a loose fit.
    I don't know if lube grooves are a good idea, it might transfer oil in or out of the swivel housings.
    Cheers Steve
    Found the following in my Autopress manual:- "The clearance in the bush should be 0.02" to 0.028" (0.5 to 0.7mm). Renew if necessary and ream to 1.25" (31.75mm)".
    Sep 2011
    Albany WA
    Gee that's alot of clearance. I didn't allow that much maybe 5 thou.
    Now I'll have to pull it apart again. Would hate it to seize .
    Thanks Steve
    It has to allow for slight misalignment between the inner and outer axles, the axes of which should intersect exactly on the king pin (swivel) axis in all steering positions, and possibly also for manufacturing tolerance on the Tracta joint.
    Aug 2012
    Thanks guys
    Aug 2012
    More now
    have had the bearings all pressed and now ready to assemble, as soon as diffs are ready.
    I'm still playing there. One of the diffs (the replacement purchase) has a pretty crook, badly worn and "ripped" drive flange at/for the Gitts seal. Some thought required or try and find another. The one out of the the dead diff good surface, ruined coupling bolt holes worn and bent, weld and re drill ?? Mmmm!
    Back to my original intent.
    Question: Given the weight of an assembled front hub and swivel, which is better:
    • assemble all on to diff carrier bit by bit, or
    • assemble the lot and fit to carrier?
    Rick F
    By "diff carrier", I take it you mean front axle housing. If that is correct, I would assemble it bit by bit - as you say it is heavy, awkward and has no "base" to sit it on!
    Aug 2012
    diff carrier = axle housing
    Build in situ, did think that would be the go. Ta. Mmmmm! Means I need to get a diff in.
    Rick F
    Quote Originally Posted by Rick Fischer View Post
    ---- badly worn and "ripped" drive flange
    There should be plenty of secondhand flanges kicking about from blown diffs and I would have one here if you get stuck.
    Need a couple of pictures to see which one your damaged one is, as there has been a few variations on those flanges over time.
    But I reckon there will be plenty to chose from up your way as well.
