Thread: Metallic clunking sound on corrugation
    Aug 2013
    ACT
    Hi
    I have had this issue since new but as I have trouble reproducing it at home for LR I thought I might ask you guys
    When driving over corrugations or rough road I hear the metallic klunk sound from inside the car. It is hard to pin point while driving but I think it may come from the steering wheel column.
    Does that make sense or even possible.
    It does not happen all the time but is consistent when I hit rough stuff.
    Any ideas ?
    Thanks in advance
    Richard
    Dec 2011
    Forrestfield WA
    The two noises that I have had in my car on corrugations are:
    1. The wheel nut covers rattle, heard with the widow down.
    2. The clunking which comes from the lower control arm bushes. That sounds like your issue but it would not have been present from new. It gets worse and worse until you realise that you have to change the bushes.
    Bob
    Aug 2013
    ACT
    Bob
    I am sure the noise is coming from within the car cabin.
    Richard
    Mar 2015
    Regional SA
    Lower steering shaft?
    My D3 suffers from a 'rattle' as each front wheel rides over rocks or uneven terrain. Has done so, since I bought it used a few months ago. I'm pretty confident that mine is the lower steering shaft, either slop in the splines, or universal joint.
    I've seen a service bulletin, I believe it's included on the owners manual (from the AULRO online Shop) for this problem, the fix is a new lower shaft.
    I'll see if I can find the info, but if you haven't done so already, I highly recommend the aforementioned CD-ROM.
    Dec 2011
    Forrestfield WA
    Quote Originally Posted by Roblott View Post
    I wouldn't be too sure about that. What you describe is exactly what the lower front bushes feel like. I thought the same as you and was skeptical when the repairers said it was the front bushes but replacing the control arms fixed the problem. At 200,000km mine now has none of that feeling of clunking in the steering.
    Bob
