Just go straight for the Battery Box. Find the earth lead and put a decent isolator switch on it. People don't expect it to be on the earth, and if you use heavier cable the lead can be stronger, allowing the isolator to be located further away from the battery, causing confusion for longer with the would be thief. If you can make/have a lead made that resembles the original, when they find the battery and see nothing wrong they look elsewhere for fancy immobilisers!!
				1995 Mercedes 1222A 4x4
1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
1991 VW Citi Golf Cti (soon to be Tdi)
'When there's smoke, there's plenty of poke!!'
'The more the smoke, the more the poke!!'
