Results 1 to 10 of 12
Thread: Can I run these wheels on an 08 RRTDV8
    Feb 2012
    Beaudesert Qld
    Got a set of 4 (see photo) of these wheels off ebay presumably from an 03-05 RR Vogue. They require a set of new wheel nuts which are square ended which I can purchase for a reasonable price.
    I fitted one wheel to the front which seemed to go on okay after a bit of moving back & forward. Seems to fit over the Brembo brakes alright but I'm not sure if using these wheels will adversely affect drivability in any way.
    Any comments appreciated.
    Feb 2014
    If they fit they should be fine.
    The offset should be the same
    the tyre size should be the same
    best way to find out is try
    Feb 2012
    Beaudesert Qld
    Quote Originally Posted by chaybra View Post
    Thanks. I should have mentioned that the original rims looked just like these ones I've just purchased off eBay (ie 7spoke & 20") except the originals don't have the "drilled holes" next to 5 stud holes. Don't know if that has any significance to wheel stability or something else?
    If they are Land Rover wheels, the offset will be embossed on the wheel, probabaly on the back, something like 57mm
    Feb 2012
    Beaudesert Qld
    Thanks. The wheels are stamped on the back "Land Rover" and "Made in Austria" also stamped 8.5J x 20. There are a lot of other numbers but I have no idea what they mean. Forgive my ignorance, but what's the offset mean & how does it affect the driving or steering of the vehicle?
    Aug 2015
    WA
    I have just put 20" on my 2007 tdv8 with brembo's, they are 20x9 with an offset of 50, fit fine. Original 19" have an offset of 53 so the lower the offset the more the wheel will sit outwards into the wheel arch. As long as your offset is 53 or lower it should be fine.
    I have 275 45 tyres and also no issues, had some 295 on for a few days and they were also fine.
    NSW SW Slopes
    L320 RRS has 20x9" with 53mm offset whereas L322 RRV has 20x8.5" with 57mm offset standard.
    Brisbane, Queensland
    Graeme
    Does the narrower rim with inc offset on the L322 mean the wheel sits in much the same spot as a RRS?
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Feb 2012
    Beaudesert Qld
    There are quite a few series of numbers stamped on the back ... can't see a "58" but there is an "IS 58" stamped on one spoke. Would that be the offset and if it is ...is it still okay to use the wheel ?
    NSW SW Slopes
    Quote Originally Posted by rar110 View Post
    The inner edge of the wider RRS rim will be about 2.3mm (6.35-4) closer to the strut than the L322 rim.
