Results 1 to 9 of 9
Thread: 300tdi vacuum pump freeplay?
    Dec 2013
    Hi all!
    Decided to check vacuim pump as there is ticking noise coming from that area. After taking it out I noticed that actuating shaft that gest pushed by camshaft has some axial freeplay in it. Is this how it is supposed to be?
    Also spring is very stiff. I can barely press actuator in with my hands assisted by knees. Does this sound ok also?
    Thanx!
    Sent from my GT-I9305T using AULRO mobile app
    St Helena,Melbourne
    4.28 MB
    The spring is highly tensioned so thats ok, you shouldnt be able to move the rod side to side by much.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Dec 2013
    Thanx! At least spring is ok. Side ti side there is no play. But axial there is.
    Dec 2010
    cairns
    vacum pump
    i replaced mine, three in a year all wabco ones, just put a indy pump. brand
    in been good 10,000 ks now and $100 cheaper.
    when this one fails $1100 to fit a electric one
    Dec 2013
    Quote Originally Posted by mudder110 View Post
    What kind of failure symptoms did you have mudder?
    Travelling OZ - Back in SE Qld again at the moment
    You've got to be joking! I've been running an electric vacuum pump from a Volvo turbo model (740?) for a few years now. Check the Volvo wreckers.
    Decided not to replace the mechanical pump as, when I took it off, a lot of the hard facing was missing from the vac pump cam lobe.
    Ian &
    Leo - SIII 109/GMH3.3
    Daphne I - '97 Disco 300Tdi Manual
    Daphne II - '03 Disco Td5 Auto
    Dec 2010
    cairns
    vacum pump
    symptoms of my vacuum pump failures were, ticking and very little braking,
    leaking from pump because of lose rivets.
    as for the $1100 price of a electric pump firstly, im not a tight arse.
    only use new parts of good quality, unlike the landrover mechanics ive come across in cairns, the only failures ive ever had have been some crap parts
    fitted by the cowboys up here, if I don't do the conversion myself I will be using bcr in cairns they specialise in hot roads, and and brake and clutch conversions, the electric pump will be from the states, the indy pump brand one im running now is going good seems they like them in Africa.cheers
    Dec 2013
    Uhmmmmm. I have ticking but no leaks and no braking problem. So don't know if it's woth taking it apart. Only thing that I can see is bit plunger axial play. Apart from that all looks good.
    May 2002
    Heathcote (in "The Shire")
    Make sure you also check the booster for cracks around the master cylinder mount. This will also take out vacuum pumps quickly as well.
    If/when you install a new pump put double gaskets under it - this seems to help life span as well.
    I'd also advise using genuine or at least a quality booster, I had a big problem with an aftermarket cheapie (- not price) couldn't get a good pedal and it was doing my head in until my son asked "should that be moving like that"
    [ame]https://www.youtube.com/watch?v=wU3CyjTFiZ4[/ame]
