                                                25th September 2015, 09:56 PM
			Auto box: "How long, Doc?"
					2005 tdv6 auto @ 250,000km:
 * Slight slippage (about half a second) when going into 4th gear only when cold, no shuddering.
 * When overtaking, hard acceleration, speed 120km/hr+, box goes from 6th to 5th gear, "transmission fault" registers, all back to normal with next ignition cycle.
 * Otherwise box is smooth and quiet, when it warms up the slippage is not apparent.
 Is this the dreaded "beginning of the end" for the box? Should I start budgeting 8 grand for a reco now?
 I have done X4 gearbox flushes since ownership in last 20,000km, and fitted the steel pan and new filter recently. The slippage was evident since I took delivery, perhaps it is more noticeable now. The oil at first drainage was not burnt or smelly, and did not feel gritty.
 I can live with the problem as it is, just want to know if others have had similar experiences, and how it ended for them.
 To sum up: "How long have I got, Doc?"
 -Wasa
                                                26th September 2015, 05:02 AM
					If it's just the tranny it won't be $8k.
 ZF Sydney do a full rebuild for $4400 + removal and refit of about $1k.
 L322 tdv8 poverty pack - wow
 Perentie 110 wagon ARN 49-107 (probably selling ) turbo, p/steer, RFSV front axle/trutrack, HF, gullwing windows, double jerrys etc. ) turbo, p/steer, RFSV front axle/trutrack, HF, gullwing windows, double jerrys etc.
 Track Trailer ARN 200-117
 REMLR # 137
                                                26th September 2015, 07:21 AM
					I would also suggest adding some Dr Tranny to the oil. It seems to have worked for others here and on the UK forums.
 http://www.aulro.com/afvb/d3-d4-rrs/...udder-fix.html
 A quick google search and you will see places to buy online. Not sure who sells it in Oz.
 Dan
                                                27th September 2015, 07:27 AM
                                                #4
					DR Tranny available from BURSONS auto parts
 Used it in my Transmission, it did improve the shudder, but its still there although seems to be mainly when cold. I wonder if it might be low oil level ?
 Les
                                                27th September 2015, 11:00 AM
                                                #5
					Thanks all, I have consulted Dr Tranny, and filled my script for X2 tubes (from US.)
 I will also check the fluid level at the same time. I recently done the steel pan and new filter concersion, and used LG6 (read: Liquid Gold Six Hundreds!!)
 The problem is brief smooth slippage, not shudder, ie the engine revs up without corresponding traction, but only for about half a second, and only when going from 3rd to 4th when cold.
 However I will obey the good Doctors orders in the belief that the medicine is safe to administer.
 I will post feedback in a few weeks.
 -Wasa
                                                27th September 2015, 10:43 PM
                                                #6
					Given the unknowns before you bought, 250k life is probably reasonable.   From what I have read (and yes done plenty of reading up on this auto given I now have it in 2 cars), Dr Tranny is good for sorting the shudder problem.  Yours though sounds more like a mechanical valve block or solenoid issue.
 So yes, hope for the best, but plan for the worse.
                                                28th September 2015, 08:21 AM
                                                #7
					Thanks Disco DB. Your reply, in part, should become standard advice for all Landrover owners and potential buyers:
 "So yes, hope for the best, but plan for the worse.[/QUOTE]"
 Thanks for your advice on solenoids / valves also.
 Cheers, Wasa.
