Results 1 to 10 of 17
Thread: Perentie (MilSpec 110 Isuzu) parts and accessories thread.
    Toowoomba QLD
    Quote Originally Posted by Moderator Note
    This thread is for publishing part numbers and information on known suppliers ONLY.
    If you have a question, DON'T post it here, ask in regular thread.
    Thanks Moderation Team.
    Key Barrel set
    From what I can determine, the Landrover part number for the lock barrel/key set is RTC3022.
    Quote Originally Posted by REMLR Website
    Barrel and key(s) for ignition switch - P/N RTC3022
    Barrel and key(s) for front door locks - P/N 395142 (contains two barrels and keys, therefore one 395142 per vehicle).
    For fitting instructions see:Fitting a key to a Perentie? Anyone done it & can give a run down of how to do it?
    Last edited by Lotz-A-Landies; 13th October 2015 at 03:51 PM. Reason: Compiling Perentie parts thread.
    East-South-East Girt-By-Sea
    1.20 MB
    Wheel brace
    OEM Perentie Wheel Brace is AYG8114.
    Replacement alternative
    An ideal replacement for the original wheel brace is the Bearmach BR 0814 heavy duty wheel brace for Defender, RRc, Disco 1 and Series 3.
    They fit easily in the Perentie tool box plus are far better than a 26mm socket and breaker bar when getting the spare wheel down off the winch.
    Cost about $28 from my local Land Rover specialist repairer. (Yes the head does fit through the hole in the body easily)
    ADDIT: I have created this thread so we can collect Perentie specific parts.
    Note: There is a thread in the Isuzu Landy Enthusiasts section for 4BD1 parts AULRO: The 4BD1 Part Numbers Reference
    Jan 2015
    Ipswich
    Fordham bottle jack repair kit
    Fordham sell a seal kit PN: SK6108 @ $85+GST. - www.fordhamengineering.com.au
    cheers.
    Quote Originally Posted by timbo72 View Post
    I rebuilt my 1980's Fordham jack for about $40 in seals, including spares. They were all standard sizes including the cup. Considering the jacks are only worth $100 at swap meets, $85 to rebuild is a bit rich.
    Fitting the cup into the bore was fiddly, but you dont need any special tools.
    1.20 MB
    Clutch master and slave cylinders
    OEM (manufacturer) for a number of parts in RPS "Z5394" Is Jaguar Rover Australia/Land Rover.
    Clutch Master Cylinder = AYG450
    Clutch Slave Cylinder = FTC5071
    Attached Files Attached Files
    1.20 MB
    Replacement Heavy Duty drive flanges.
    The Hi Tough Engineering* part number for the Perentie drive flanges is HTE-5806 and is a direct replacement for the OEM part.
    * Hi Tough Engineering is the successor company to Maxi-Drive axles.
    1.20 MB
    Sliding Window seals/repairs
    Oct 2013
    Adelaide
    Fuse cover for RFSV (relocated to dash) old number BTR2307 New number YQH101080 less than 1/2 price of previous ($34.85).
    I thought a spare might be useful to drill holes in, to mount GPS etc.
    1.20 MB
    Perentie 110 brake booster.
    The booster is a VH514 PBR. Easy to get hold of thru the brake mobs. (As per http://www.aulro.com/afvb/2493373-post3.html) May be typo, see next entry
    Perentie 4x4 RPS specifies: PBR part No.: VH524 or Land Rover Part No.: AYG2797 (as per http://remlr.com/forum/index.php'topic=4120.msg40855#msg40855)
    Perentie 6x6 RPS (02209) specifies: PBR part No.: VH516 or Land Rover Part No.: AYG2669 (As per Brake booster problem
    Perentie Brake Master Cylinder
    Perentie 6x6 RPS (02209) specifies: PBR part No.: ???? or Land Rover Part No.: AYG439
    Anecdotal information is that the Perentie 4x4 M/C is the same part as Falcon XC XD utility and station wagons, but used a different plastic reservoir.
    Aug 2009
    ACT
    Perentie - PTO (Thomas) winch shaft uni joints
    Couplings are Hardy Spicer, 3/4" bore with 3/16 keyway. Part No.s are:
    Slip Yoke (ie long one): 10-3-13X
    End Yoke: 10-4-13
    UJ: 5-170X
    You'll also need an appropriate grub screw and grease nipple which don't come with the couplings. I bought everything from a local Canberra bearing place (who were able to source it from HS overnight) for about $200 and fitted it yesterday.
    And just FYI, I did try to buy it from Hardy Spicer direct when I was in Sydney. They didn't have the slip yoke on the shelf and they guy I was dealing with was adamant it was a splined yoke. Admittedly the catalogue is a little confusing but I can assure you 10-3-13X is the correct one; ie plain bore with keyway.
    Simon
    Last edited by Lotz-A-Landies; 29th February 2016 at 11:26 AM. Reason: Copy relevant parts to Perentie parts thread
    Mar 2015
    Drive belt is Isuzu part # 1136714641 ($22.44)
    Engine Oil sump plug gasket is Isuzu Part # 894 107 5640 ($3.95 ea and they only sell them in a pack of 5)
    Engine oil sump plug is Isuzu part # 894 107 5570 ($18.95)
