Get used to it. I've found that when the Dist to Empty shows 0 km I have nearly 100 theoretical kilometres left. Somewhere in the workshop manual it explains the methodology behind it. Basically they don't want you to run it to empty so it cuts out for the first time when there's something like 4 litres left. You can then restart it and drive on. There is a second event after that.
"In the event that fuel is allowed to run too low, signals transmitted from the fuel level sensors initiate the fuel rundry strategy. The driver will be notified before the tank is run critically low on fuel. Although this is a simulated rundry
procedure, it provides the symptoms of the vehicle running out of fuel and the driver will perceive it as such. The engine will stop when there is approximately 4 liters (0.87 gallons) of fuel remaining in the fuel tank."
