Disconnect the battery before removing the alternator
Drain the fluid from the block via the drain bung on the side between the alternator and turbo.
Loosen the water pump and p/s pulleys before you remove the serpentine belt.
release the p/s pump but leave it all connected, just lean it forwards.
Use a metal P-Gasket, there are still paper ones getting around.
				'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
