If you're good with electrcky stuff, check this thread:
http://www.aulro.com/afvb/communicat...ch-wiring.html
It may be of some help
Dear all,
I have a rear maxidrive locker on my def 90..super happy with it, does the job first time right. However due to a recent accident the vacuum witch in the cabin to activate the locker, is broke.
Any pointers from where I can source a replacement please? The Googlenet is not throwing up good results for me.
Kind Regards
Or try this. I believe it is similar:
http://m.ebay.com.au/itm/Clippard-Mi...-/121472979252
Contact MR Automotive in Redcliffe, they sell Maxi drive products. There are 2 types of switch. The original was an actuator and switch in 1, it ran the vacuum hoses to the actuator and is recognised by a brass nob. The later design sold by MR Auto when they took over the product line is a plastic nob which is an electronic switch for a remote relay/actuator. MR Auto should be able to sort you out for either type.
MLD
I will have the original brass pneumatic switches somewhere, let me know if you are interested, and I'll search for them.
Michael T
2011 L322 Range Rover 4.4 TDV8 Vogue
Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
