                                                13th October 2015, 07:28 PM
			shredded rear top shocky bushes
					had to do a trip over the weekend to a bushfire which needed about 400km on highway. a few unusual noises started about half way which appears to  be shredding of the top shock absorbers bushes.  Truck normally just runs around home or doing farm stuff They were OME  yellow ones and yes a few years old.
 not sure if failure is due to age or upcoming mechanical failure somewhere else.
 Any thoughts?
                                                13th October 2015, 09:51 PM
					By shredded have they fell apart in strips or have they crumbled into pieces? The yellow bush's do seem to fall apart when a few yrs old I have found and they do crumble. Maybe the long road run induced more heat and shock loading than paddock work did.
 Cheers Scott
                                                14th October 2015, 09:56 AM
					Grease  They need to be greased when installed, and then maintained They need to be greased when installed, and then maintained
                                                14th October 2015, 06:50 PM
                                                #4
					Ah yes, should have mentioned that, though I took grease as a given. I have had them crumble from age even with greasing
 Cheers Scott
                                                15th October 2015, 07:11 AM
                                                #5
			crumbled bush
					had a look in better light and found a lot of yellow crumble. must be just old. have obtained some repco bushes so will try them for the next 20 years .
