Results 1 to 10 of 37
Thread: I put it in a safe place
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    Sometime early last year I put my close to brand new electric soldering iron "some place safe". I then had one of those days where I wanted to test a car battery and I found that the battery in the multimeter was flat. When I took the 9 volt battery out one of the terminals had corroded on. This meant that the terminal stayed attached to the battery and separated itself from the terminal clip. One of the wires also pulled out of the terminal
    Easy fix it will just take me five minutes with the soldering iron and I will be back in business. Of course the safe place were I last stored the soldering iron was not forthcoming and it refused to relinquish its hold.
    Today, after moving interstate for work and then coming back home, getting another job that involved intra-state travel I have had some time to fit a new battery clip. Because the safe place still has its relentless hold on the soldering iron, I went to a hardware store. It took me nearly half an hour to decide which one to buy do I want a two power iron or a single power, or a two power with a desk station?
    Anyway, job done and I can put a battery back in my multimeter.
    Where am I going to store the new soldering iron? Not in a bloody safe place that is for sure! What is the bet that the next time I go into my shed the old soldering iron will come out of its safe place.
    Kind Regards
    Lionel
    May 2003
    On The Road
    no ones borrowed it?
    Western Victoria
    Put it in a safe place. You'll find the other one is already there.
    Bob Harding Guest
    Ha bin there done that more times than I can remember tis called
    Senior Moments so enjoy them while you can cause the next stage is terminal
    I have been told
    PS
    My shed is chocka block with things I cant find or dont realise that I have misplaced yet
    Hay Point
    Took me 18 months to locate a Salisbury diff spreader that I put away "in a safe place". Bloody CRAFT.
    Cheers......Brian
    1985 110 V8 County
    Apr 2002
    Bellara 4507
    32.43 MB
    Quote Originally Posted by Bearman View Post
    i'm still looking for my little hand winch i tucked away in a safe place when i moved into the shed in lear jet drive a few years ago
    i was hoping i would find it when i was moving out and into the shed at home
    still looking
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Cranbourne North
    I am in the process of packing up my shed to move. Just quite amazing all the hidden treasures I have found hidden away over the last fifteen years. Yep and some stuff that I now have two of
    Cheers Hall
    Dec 2012
    Stuart Town
    I put a boat rego sticker in a safe place about 5 or 6 years ago. Yep, although I have turned the house over a couple of times, it's still safe.
    Tom.
    1996 Disco 1 300TDI manual - Lucille a cantankerous red head! :D
    1997 Disco 1 300TDI Auto - sold
    May 2008
    Bundaberg Qld
    Quote Originally Posted by incisor View Post
    still looking
    What the little "come along" one ?
    Apr 2002
    Bellara 4507
    32.43 MB
    Quote Originally Posted by pop058 View Post
    like a little boat winch but with strapping not wire...
