Thread: Speedo drive cable
    Oct 2015
    Adelaide
    Speedo drive cable
    Hi Everyone
    Has searched and not found an answer
    I have a mongrelised 2a - now with a 202 motor in it. as best as I can determine it has a series 2a gearbox fitted. However it is lacking a speedo drive cable, and there appears to be several variants on the market.
    The Jaeger Speedo has a screw fitting, and appears to be working well, after a clean.. attached is a pic of the speedo drive on the gearbox
    any help to identify the right one would be appreciated.
    Nic
    Apr 2014
    Blair Athol, Adelaide South Aust.
    Looks like the cable has broken off that small round disc bolted to the gearbox. Standard 2a cable with screw on fitting for the speedo head is needed. Dont lose the two bolts that are left and try find another one. New cable is secured to gbox with those 3 screws. Cable has the plate as part of itself. Job done.
    Cheers Rod
    Sent from my GT-I9507 using AULRO mobile app
    JDNSW's Avatar
    As Rod says. You need a Series 1/2/2a speedo cable. It is fastened to the transfer case by that round plate, which comes as part of the cable. It is fastened by three screws, 4BA, I think from memory.
    Cessnock NSW
    The screws are 2BA and there are 3 of them, cheers Dennis
    Oct 2015
    Adelaide
    thanks for the input and feedback everyone. have ordered a cable so we'll see.
    Does anyone know where I can source the little coloured lenses that sit on the dial plate from - one is missing
    thanks again
    Nic
    JDNSW's Avatar
    It may be inside the speedo - I think they go in from behind. But if not, a likely source might be in the wanted sections of this forum, there are probably plenty of dead speedos with these still intact about.
    Oct 2015
    Adelaide
    Hey everyone
    a year later and I have the speedo working - she worked on a new cable, but was about as reliable as...
    had the speedo serviced, and she is now as good as gold.
    we have cracked 50 in her. pic was taken at Carrieton SA a few weeks ago
    Dec 2009
    Queensland (though occasionally elsewhere)
    That photo shows you hitting the fabled 17mph barrier.
    Steady on...don't push her....
    JDNSW's Avatar
    A couple of points on this thread -
    1. Speedo cable is different between the six and the four, as the gearbox is further back on the six
    2. I don't think that Series Landrovers were ever fitted with speedos with chromed bezels, although some may have had them to special order, or it may have been some owner's 'bling', as similar speedos with chrome bezels were common in English cars in the 1950s, 60s and even 70s.
    Oct 2015
    Adelaide
    Thanks John
    This was a 6 in its day
    not trying to be purist - as long as the thing is indicative to within reason
    Nic
