Results 1 to 6 of 6
Thread: Hilux problem
    Sussex Inlet. N.S.W.
    Hilux problem
    My 1993 Hilux has a strange problem. I suspect contacts on the ignition key barrel but I am not sure. The problem is that it almost never starts when I turn the key, until I release it and turn it for the second time. It then starts every time. I have fitted a new battery but problem continues. Am I on the right track? Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Douglas Park, NSW
    Quote Originally Posted by jx2mad View Post
    Does it crank the first time?
    Dash lights on then go out on starter contact. No cranking at all
    Jim VK2MAD
    '17 Isuzu D-Max
    That does sound like the switch.
    Seems strange that on the second attempt it fires normally
    Jim VK2MAD
    '17 Isuzu D-Max
    Williams West Aust
    Worn contacts in the starter motor,the current is having to jump too bigger gap,eventually nothing will happen.See if contact kits are available for the starter motor,would be surprised if they arent.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
