Results 1 to 10 of 14
Thread: RRS front air suspension unit minor leak
    Byford, WA
    Hi There,
    I have a minor leak in the front air suspension circuit. Prior to me buying the owner had two front air suspension units fitted, somewhere, not local to me, whilst I thought about warranty I suspect not.
    I have done the bubble test and found a very minor leak around the front air pipe connection to the drivers side air suspension unit. Is the Voss fitting one that can be tightened or is it like the P38 fitting which is a push the collar and pull the pipe to remove. Looking with a mirror it looks like a hex fitting on top, however I thought I had better check.
    As with any Land Rover component easily accessible......... ho ho ho
    Is it easier to let the top bolts holding the air suspension unit in place go and drop the unit down a bit to get better access (depressurised of course)?
    Thanks for any assistance rendered.
    Cheers Marty.
    Byford, WA
    Not very often this happens.................
    Hi People,
    What nobody knows?
    Dec 2011
    Bundeena
    Does this help in any way?
    [ame]http://www.youtube.com/watch?v=7VQ2kbIKgEw&t=558[/ame]
    Sean
    Byford, WA
    Hi Sean,
    I had a look on YouTube and didn't find anything, obviously looking in the wrong spot. Great thank you.
    Cheers Marty.
    Dec 2009
    Ranelagh, Tasmania
    And another one [ame="https://www.youtube.com/watch?v=PaOWxVMqH-c"]https://www.youtube.com/watch?v=PaOWxVMqH-c[/ame]
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    NSW SW Slopes
    The valve block can if necessary be released from its mount for better access without releasing any air - just be careful not to kink any of the 3 plastic pipes.
    The fittings are screwed so can be tightened although the valve blocks have been known to develop splits which then requires a new valve block to be fitted. Its not normal to undo the pipes at the block to replace front struts.
    NSW SW Slopes
    This might be useful.
    valve block.pdf
    The connector into the air bag is a Voss-type screw-in connector. If the connector is leaking around the thread but not damaged, you can unscrew it, apply some Loctite 243 and refit.
    If it's leaking around the input of the airline to the connector, then you'll have to replace it if a simple re-tighten doesn't seat it correctly.
    Gordon
    PS use a stubby 12mm open-ring spanner to remove.
    NSW SW Slopes
    Hmm, I didn't realise that the leak was at the air-spring!
    I would just try to tighten it first as its a PITA to refit once removed. I would not use a thread locker as the joint is not one that works loose and laborious enough to unscrew without thread locker. I R&R'd many and never had a leak so suspect that the nut isn't quite tight.
    Byford, WA
    Hi There,
    More than enough info now, thanks very much everyone. When I saw the hex I was a bit wary expecting a push collar connection like the old P38. I am assuming that this is a Voss 203 connector. The hex was tight, the air leak was between the pipe and the connector, I couldn't see any leak between the connector and the air spring, saying that it as pretty difficult even with my mirror to see.
    I'll get a couple of new connectors and change them out, just hope the pipe hasn't been damaged when whoever it was replaced the air springs. The job of removing the air spring doesn't look that bad. There is a small slot directly above the inner nut, if I "trim" that tab I will be able to get a socket with an extension from the engine bay which will make getting to that a lot easier.
    Cheers Marty.
