Results 1 to 8 of 8
Thread: next job transfer rear output flange
    Dec 2010
    cairns
    howdy all, since my recent experiences with workshops, im doing as much maintenance as I can myself on my 110 defender 300tdi
    going to check the handbrake drum and ajust up or replace the shoes
    may as well do the flange, my question. is there a bearing behind the flange that I can or should change while im there and can it be done without major surgery? any other advice would be great cheers all.
    Feb 2005
    If it's not leaking than leave sleeping dogs lye
    Dec 2010
    cairns
    output flange
    feels like some movement when when I put pressure on the brake drum
    have a small leak running down the transfer case like real small cheers
    Feb 2005
    Geez from memory there is some movement......hopefully and confirm
    The leak could either be the seal or through the splines....we but its been a while since I have had one off
    Bearman's Avatar
    Hay Point
    As weeds said there will be a small movement as the end of that shaft goes into the centre diff and its not exactly an interference fit. Have a good look at where the leak is coming from - most likely its from the the intermediate shaft in an LT230.
    Cheers......Brian
    1985 110 V8 County
    Aug 2012
    Logan,Queensland
    The rear flange is easy to remove insitu.
    you can replace the rear seal and the felt washer as well.
    use a new nyloc when putting it back together.
    nothing tricky, its is just torqued up.
    I replaced the seal on one recently and the m20 nyloc was barley finger tight.
    There is a dust cap on the back of the transfer which needs to be tapped off to allow the seal to be changed.
    Good time to put some fresh bolts in the flange for the rear shaft.
    '95 Defender 130 Single Cab
    HS2.8 TGV Powered
    98% of all Land Rovers built are still on the road.
    The other 2% made it home.
    Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
    Dec 2010
    cairns
    output flange
    will do a full investigation, is there a bearing in there that should be changed with the flange thanks for the advice
    Bearman's Avatar
    Hay Point
    Quote Originally Posted by mudder110 View Post
    There is a bearing but not worth changing unless its noisy or vibrating.
    Cheers......Brian
    1985 110 V8 County
