Results 1 to 9 of 9
Thread: Another p38 up in flames
    May 2010
    Mindarie, Western Australia
    Hopefully no one on this forum
    Car fire shuts down Tullamarine Freeway
    Gary
    2007 Range Rover Sport TDV8
    Modified 1996 p38a HSE sold
    St Helena,Melbourne
    4.28 MB
    I could see the smoke from work just a few k's away.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Feb 2010
    Townsville, QLD
    Oh dear...
    Jul 2014
    OMG still can't believe how lucky I was putting mine out!
    2000 4.6 HSE Alveston red
    2007 307 xse peugeot
    1974 xj6l jaguar
    Feb 2013
    Gosford, NSW, Australia
    damn
    Feb 2013
    Ballarat,Vic,Aus
    Why are they burning Is there a pre-existing fault owners should be checking for
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Feb 2013
    Quote Originally Posted by DoubleChevron View Post
    seeya,
    Shane L.
    Some possible causes which have been mentioned
    1) we have seen pinhole failures in coolant hoses start a fire
    2) My MY99 I suspected a fuel fire caused by a faulty pressure valve in the fuel system
    3) on rr.net people have pointed to the high pressure brake hose which runs from the pump to the master cylinder
    4) There have been a few fires in fuseboxes
    There may be more as well
    5) Another tip from the P38 FB page by Steven Libstaff
    Decaying oil cooler lines leak oil onto the exhaust system and it drips on and coats the cats where it ignites. All new oil lines in mine.
    Steve
    garybrook Guest
    Replacing o-ring on transmission oil pressure line
    Steve,
    regarding you replacing your oil lines - which I presume were your transmission oil lines if they were leaking onto the cats - can you tell me how you replaced the pressure line o-ring on the top of the transmission case.
    My gearbox is a ZF 4HP24 and it looks impossible to remove the line and o-ring, without lowering/dropping the rear mount - or all mounts including the engine ones - and support the lot while I replace the o-ring. It seems a risky business unless there's an easier method, through the top of the selector panel?
    I replaced my return line o-ring earlier when I was flushing the whole transmission cooling system, as well as the two others on the engine sytem. Cheers,
    Gary.
    Feb 2013
    Quote Originally Posted by garybrook View Post
    Steve,
    Gary.
    Hi Mate
    It wasn't me who replaced my oil lines, that was part of the quote from a guy on FB. My transmission oil lines seem to be in pretty good shape, but I am certainly going to keep an eye on them !
    Someone on here will be able to answer your question I am sure
    Steve
