This is the one I fitted to my 05 TDV6 in the caravan park at Katherine back in August.
Still going strong.
Alternator Rectifier FOR Denso Magneti Marelli Ford Volvo Mazda 237607 | eBay
 Fossicker
						Supporter
						Fossicker
						SupporterCan anyone confirm the correct rectifier for an 08 d3 Tdv6 is inr437?
Matt
 Master
						Supporter
						Master
						SupporterThis is the one I fitted to my 05 TDV6 in the caravan park at Katherine back in August.
Still going strong.
In case you haven't seen them, here are the instructions on replacing them:
[ame]http://media.disco3.co.uk/gallery/albums/userpics/11480/Replacing2_the_Diode_Pack_on_A_Denso_Alternator.pd f[/ame]
Get to it early as when they fail in a big way the resulting heat etc can damage regulator and ive even seen stator winding insulation heat affected. Generally speaking i would be replacing the alt as a unit when they fail at around 150k as there are lots of other wear factors to take into consideration.
Jc
 Swaggie
						Swaggie
						The alternator on my brother's 08 RRS had burnt insulation on windings after it failed.
