No one?
I can see this has been covered a bit but I can not seem to find a definite answer.
Can the RRS front lower control arms be used as a direct replacement in a D3?
No one?
Hi Will Wallace,
I'm pretty sure they fit however I haven't fitted them to a D3. I think there is some difference, something about the anti roll bar, maybe it is just a bigger diameter. I do know that the RRS sport arms are a stronger build than the D3 ones.
I usually only like to comment on something I have actually done. Sorry I can't be more help.
Cheers Marty
I have fitted the RRS arms to my D4 and am pretty sure they also fit the D3.Contact Steve at 003HD HEAVY DUTY FRONT LOWER ARM KIT HD ON DISCOVERY 3 - STANDARD ON RRS MODELS he will advise compatibility.
Thank you very much folks. Will be doing this over Christmas then.
Thanks again.
 Fossicker
						Fossicker
						Some say with the Super Pro bushes the ride is not as smooth as the original bushes,although they should have a longer life.
Hi Eddy,
The ride is shocking, I replaced my Polybush bushes with originals about three months after I had installed them. Easy to fit etc however the down side is the harshness of the ride and road noise.
Cheers Marty.
Why not rebush original it's so cheap n easy n the ride is factory
 Master
						Supporter
						Master
						SupporterIs it really that easy? I had the impression from what I read that it wasn't worth rebushing, I've just bought a pair of LCAs from advance factor but have not fitted them yet, though I don't intend to throw the old ones away just yet incase rebushing is easier than I have read.
The special tools in the pdf are what put me off, am I wrong?
