Results 1 to 3 of 3
Thread: Adjustable panhard rod bushes
    May 2008
    cairns
    I am using a ruff dog adjustable panhard rod and after they told me I could use the OEM rubber bushes in them I found out they don't fit . has anyone found a adjustable panhard that will use a rubber bush .
    Oct 2007
    Brisbane West
    Its a bugger. I ended up using the nylon bushes which i hate and have $70 worth of the steel and rubber Uk genuine LR ones i wont be able to use unless the inner face of the eyes are machined out. Hate neurothane or whatever they are called.
    May 2008
    cairns
    I will never put polyurethane bushes in my truck ever again . looks like I'm going to have to cut the rings off and weld on 35mm ones to allow for stock bushes or use a patrol panhard and bore out the bolt holes on the bracket
