Thread: Disco 4 locking diff????
    Jul 2013
    Darwin
    New Disco 4 owner. How can I tell if my 2010 TDV6 SE (3L) has been optioned with locking diff? I assume there is a button somewhere.
    NSW SW Slopes
    Here's a picture of the 2.
    Diffs.pdf
    The easiest way to tell is to look at the diff from behind the vehicle and see what side plate / cover is fitted on its left side - flat or bulging. The main casing is identical for both.
    Jul 2013
    Darwin
    Yeah but how do you turn the locker on and off.... Surely there is a switch somewhere in the cabin that activates it, which I assume would be a dead giveaway that it is fitted, or not.
    LRD414's Avatar
    Oct 2014
    Quote Originally Posted by The Fizz View Post
    No buttons. Not driver selectable for either the centre diff or the rear e-diff, if you have it.
    If you've just got the D4 recently, I highly recommend the FAQs sticky thread on the forum here. It covers a lot of great stuff including a bit on the diffs.
    http://www.aulro.com/afvb/d3-d4-rrs/...4-rrs-faq.html
    Also, if you register with Topix then the VIN can be used to show the build information and options included.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    SBD4's Avatar
    SBD4 is offline A Keeper of the TGO Gold Subscriber
    Dec 2011
    Bundeena
    Sign up to topix & enter your vehicles VIN. It will show you every detail about your cars build options. Its free too:
    https://topix.landrover.jlrext.com/topix/user/loginForm
    Edit: Scott just beat me to it!
    Sean
    Sep 2011
    Minyama
    Have a look on the 4X4 screen. Does it show the rear diff with similar green segments as the centre diff?
    SBD4's Avatar
    Dec 2011
    Bundeena
    Quote Originally Posted by rufusking View Post
    This is only relevant for newer cars where LR deleted the diff lock symbol from the 4x4 info screen for cars that did not have it -- 2013 on I think. For 2010 - 2012 the green symbol is there regardless of whether or not you have the ediff, the only way to tell if the ediff is installed, via the 4x4 info screen, is to put the car into a situation where it has to activate the ediff to see if the symbol turns red (locked). If you don't have the touch screen you have to visually ID the diff or check on topix.
    Sean
    Aug 2008
    Perth, WA
    37.36 MB
    Also, if you get a chance, grab a copy of Gordon's training manual (GGHaggis on AULRO) which you will find invaluable and covers this in detail. I can highly recommend his driver training course as well. If you haven't been exposed to late model Land Rovers and are coming across from other makes of cars, it will require a different style of driving on your part to get the most out of your new baby. Either way, enjoy!
    Jul 2013
    Darwin
    Problems with TOPIx logon
    Hi. Having problems with the TOPIx registration and logon.
    Any chance someone who has access can PM me and check my VIN for me, and send specs through please.
    TIA
    dmdigital's Avatar
    PM your VIN and I'll look it up
