Thread: Perentie Heater not working?
    Beaumaris Melbourne
    Just posted have bought a Perentie and the mechanics said the Heater is not working which is an issue for demisting the windscreen - they were going to have a look, but is this tricky? - should I maybe take it to a Land Rover specialist - any suggestions for simple fix, or are there any things they should be doing or looking out for?
    Just keen to get it on the road for this weekend.
    Do they have one?
    Western Victoria
    Not tricky at all. Mine didn't work. The fan kept blowing the fuse.
    I bought a new fan, problem solved.
    Heater/demister not working is rather broad. What is the actual issue?
    Just ignore Ron's comment. He has no idea what a real Landrover is.
    Feb 2005
    Even when they are working don't expect it to do that well......
    its also flap and cable controlled, its not uncommon for ham fisted operators to keep working at the levers until the cable comes out from one end or the other or if its a northern vehicle thats never had the heater used then they're probably rusted away.
    Beaumaris Melbourne
    Thanks guys will go and see them
    In the morning and go over those suggestions
    Feb 2014
    Perentie heater
    Sam,
    There are 2 parts to the heater.
    The blower and heater matrix is the box on the fire wall inside the engine compartment on the passenger side.
    The fan is inside this box and is one of the main culprits of a non functional demister/heater. It is controlled by the lever on the left of the dash binnacle (fan and open/closed). The fan has 2 speeds when you push this lever down.
    The temperature lever on the right of the binnacle also end at this box.
    The other part is behind the dash.
    This part controls the flow to feet or demist. This is controlled by the other lever on the right of the binnacle.
    As Dave said the culprits here are the cables that rust and seize up.
    I would put my money on either the fan or the cables as the others have said. Mine had issues with all three cables and the fan!!
    Regards,
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Beaumaris Melbourne
    Thanks guys not sure what it was but they got it working and reg on Thursday!
    Best 4x4xFar Guest
    Heater
    Quote Originally Posted by Mick_Marsh View Post
    Was it a mission to get the fan out, and where did you get the new fan from? Thanx
    Western Victoria
    Quote Originally Posted by Best 4x4xFar View Post
    No. It's not a mission.
    I got the new fan from one of the o/s suppliers.
    Here's one:
    Land Rover Heater Blower Assembly Genuine Boxed New - UTP1267 | eBay
    Or here without the in line surpressor:
    LAND ROVER DEFENDER RHD HEATER BLOWER MOTOR TO`94 | eBay
