Results 1 to 10 of 15
Thread: Ways of mounting number plate?
    Babs Guest
    Hi Guys,
    Just got the plates for Bongo today as it couldn't get NSW Rego being from SA.
    So ATM I have the rear plates zip tied to the spare wheel. They are the black and white NSW plates.
    So I plan on drilling the number plate bracket that sticks out on the back but was reluctant to drill or self tap to the body panel.
    I read somewhere and I might sound a little naive that steel screws could react with the alloy body , so I am not keen on drilling into the panel without checking first. I also thought about just putting a couple of dabs of sikaflex on the right side of the number plate. I figure a top and bottom bolt on the bracket that sticks out would be enough to keep it secure and the Sikaflex on the other side to keep it attached to the body panel.
    What are your thoughts, would I be OK to just go ahead and self tap into body panel or will I need some sort of coated self tapper. Like gal or zinc plated etc.
    Cheers I appreciate your opinions on this one,
    Babs.
    Sent from my iPhone using Forum Runner
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by Babs View Post
    Hi Guys,
    Babs.
    Yes a common (and usual) occurrence with dissimilar metals.
    Sorry I can't help with the number plate fixing. I can't remember how my rear number plate was fixed on the Defender.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    alien's Avatar
    alien is offline A Keeper of the TGO Silver Subscriber
    Bacchus Marsh Vic.
    I changed mine from screws to bolts and nutserts when I changed the plates.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Aug 2013
    Lake Macquarie
    You could look at using this stuff
    https://www.whitworths.com.au/main_i...AbsolutePage=1
    Sent from my D6653 using AULRO mobile app
    Babs Guest
    Quote Originally Posted by alien View Post
    Is there alloy nutserts?
    May 2014
    Tamworth NSW
    Yes there are Al nutserts. They don't take a lot of torque to strip out though. Food for thought.
    IIRC, in Aluminium, order of preference would be (best to worst) Aluminium, Zinc (Gal), steel, stainless.
    -Mitch
    'El Burro' 2012 Defender 90.
    Douglas Park, NSW
    There's steel & aluminium rivnuts/nutserts. The aluminium type are the easiest to fit if you don't have the tool for the job too.
    NSW far north coast
    FWIW I just used used two large head aluminum rivets on the 130 rear number plate.
    Been like that since 2002 without issue.
    Babs Guest
    Sweet, alloy Rivnuts are the way to go.
    Where is the best place to buy them? Will Bunnings have them or would I have to go to a Supercheap, Repco etc.
    JDNSW's Avatar
    All my number plates are pop riveted on with alloy rivets - makes them slightly less likely to be stolen by opportunists (a determined plate thief will have a battery drill). Also won't shake loose.
    Used this for many years without issues.
