Results 1 to 10 of 15
Thread: Alternator
    Oct 2014
    Northern NSW.Australia
    Alternator
    Hi,
    Just wondering, what is a straight swap, for the old series 3 type ????
    I have only the one fitted to the Holden motor, looks the same type as those fitted.
    But I think it reads 15amp ???? Would this be correct for the 186 Holden ????
    Any good for the 2 1/4 petrol. ( pushes out nearly 14 volts )
    Was going to have a look in the. Local car yard,for one.
    Or do I fit a new after market one.
    Whitehillbilly
    Up to you - I went to a local auto electrician and told him I wanted a replacement for the alternator in a Series 3. "No problems! $150". It does not have a brand on it, but seems to work well.
    Irymple, Victoria, Australia
    Quote Originally Posted by whitehillbilly64 View Post
    Hi,
    Whitehillbilly
    If it's a Bosch on the 186 it should be 35 Amp.
    However some of the Belmonts of the era (HK, HG, HT) had Lucas electrics, but I wold expect they were still at least 35 amp.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Oct 2014
    Thanks gents,
    will get some pics.
    Update, Lucas, 15AC.
    so will this run ok on Gilbert plus Radio/CB and lights.
    Battery Is the older one from my Mitsubishi Challenger V6 ( 760cca )
    whitehllbilly
    Oct 2015
    Tasmania
    I think I purchased what John did, an alternator with no brand. Sadly mine cost a tad more than $150, more like $200 from roverparts
    It fitted straight in and hooked right up to the existing two wires and works correctly. I pulled off the original alternator and it had squeaky bearings. I pulled it apart to replace them and looked at the general condition inside and out, which was awful, hence went with the new one.
    Thanks gents,
    will get some pics.
    whitehllbilly
    A bit here on AULRO about it.
    15AC Alternator upgrade?
    Specs here.
    It is 34amp, or should that be 34 Lucas Amps
    NAPA AUTO PARTS
    Cheers, Mick.
    1971 S2A 88
    1972 S3 88 x 2
    REMLR 88
    Oct 2014
    And to test amps from it with a multi meter I should ????
    whitehillbilly
    Quote Originally Posted by Aussie Bob View Post
    This bloke commented "That's the old price, I'll have to charge more for the one I get to hold in stock."
    Bosch make an alternator that is the same size and mounting pattern as the Lucas 15ac, but with more output and better components.
    Aaron
    whitehillbilly
    Run the battery down a bit. At a fast idle, with all accessories and lights on, use a clamp meter on the output wire of the alternator.
    Aaron
