Thread: Central locking faulty
    Sep 2013
    Hey there....is there anyway to bypass the automatic locking and manually open tailgate on my 99 P38?
    The locking system is ****ting itself....keeps locking/unlocking when I'm driving
    For your interest- key fob works fine
    Feb 2012
    Carnegie
    I installed a pull cord on the lower tailgate, just in case. If you remove the liner trim from the lower tailgate, you should see where to pull to make it work.
    Douglas Park, NSW
    You have a problem in the O/S/F lock. It'll need the microswitches sorting out, failing that, replacement.
    Oct 2007
    Williamstown, Victoria
    I had the same problem a while back, in the short term, I found if I held the switch down for a few seconds it did unlock the tail gate.
    The cause of the problem was my drivers door latch, which was causing other weird problems like the doors locking and unlocking themselves while driving, tailgate not operating properly, also unlocking while parked on a hot day, not exactly what I'd call ideal security!
    The drivers door latch is like a master switch that controls all the locking mechanisms, including the tailgate, if it is faulty you will get problems like you are describing.
    It's not very hard to replace, get yourself a new drivers door latch and replace it.
    You can find them on ebay if you have a good look, otherwise a landrover parts supplier.
    There is a guide I followed here: Replacement of door latch 4.0/4.6/p38A)
    Also a thread here: If you ever need to replace your driver's door latch .....
    A great tip is once you are in the door cavity, undo the screw that holds the door handle in place, the handle can be swung out and allows access from the other side of the door, makes life much easier, believe me!
    Good luck with it, hope that helps.
    Feb 2013
    Gosford, NSW, Australia
    +1 for the drivers door lock, I had the same issues !
    IMO it's worth getting a new lock if your budget extends that far
    Good luck !
    Steve
