Results 1 to 4 of 4
Thread: Rear Air Bags
    Mar 2011
    South Aust
    Rear Air Bags
    My D1 rear has sagged a bit over the years and as I tow my 15 ft van a bit more these days im thinking of fitting some Air Bags to the rear. What are peoples experience with towing with them? I usually use load levelling torsion bars but think the Air Bags might kill 2 birds as when we go anywhere without the van on and loaded the rear is a bit low.
    Thanx
    May 2003
    On The Road
    Air is great,
    something like these?
    I wonder how hard it is to adjust pressure?
    Douglas Park, NSW
    wonder how hard it is to adjust pressure?[/SIZE][/COLOR][/FONT]
    They link to a common Schrader valve located somewhere convenient, usually on/near the rear bumper.
    Huntly via Bendigo
    You can also as part of the air bag man get a kit with a gauge and switch to adjust from the cab if you wish.
    I have a set on my puma and before that they were on my td5 easy to fit on work very well. When we go away loaded with the camper just pump them up to about 18 to 24 psi and you are set. Mine have the valves at the rear of the back cross member and work quite well. Only thing is keep the nylon tube clear of the exhaust.
    Lindsay.
