Results 1 to 9 of 9
Thread: RRS TDV8 2006 noise
    Byford, WA
    RRS TDV8 2006 noise
    Hi There,
    This is what I would regard as a normal noise I am just wondering what it is. When I turn the ignition on there is what sounds like a high speed whining noise, not sure it is there when the engine is running. Turn the engine of and the noise continues on after the ignition has been turned off, possibly for two minutes or so.
    Is this some sort of pre and post engine running lube system? Something to do with the fuel system?
    Cheers Marty
    May 2003
    On The Road
    if its running after maybe air-suspension?
    Byford, WA
    Hi Pedro,
    Appears to be coming from the engine bay area, not passengers side underneath. The frequency is a lot higher than the air compressor. I have only noticed this noise on the TDV8's not the V6 or V8 4.2.
    Cheers Marty
    Oct 2014
    Marty, I have always heard the same (or similar) thing with my TDV6 in the D4, both ignition on but not running and also after turning off for approx 1-2 minutes. I vaguely recall reading somewhere what it is but can't for the life of me remember what now sorry.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Oct 2013
    Old Toongabbie, Sydney NSW
    Quote Originally Posted by Nomad9 View Post
    Hi Pedro,
    Cheers Marty
    I have a D4 and wondered what a high pitched noise on the passengers side was. Expert opinion here was that it was the computer doing it's thing before shutdown. Could be something similar ???
    Martin
    Byford, WA
    Hi Letherm,
    Sounds a bit more mechanical than a computer. I had the Faultmate hooked up this morning checking other things out, must have been on for about 10 minutes without the engine running. The noise I described never went off, turned the ignition off, ran for another maybe 2 mins and turned off.
    It is a "normal" noise I know it is nothing to worry about just curious........
    Thanks LRD414, no doubt it will all coming flooding back when someone recalls what it is.
    Cheers Marty.
    Sep 2013
    Our 08 freelander 2 did that noise - I thought it might be something to do with the diesel return system from the injectors ?
    Or could it be a vacuum pump for the brakes ?
    Williams West Aust
    My MY14 D4 has a high pitched noise when the ingnition is switched on and shut down,comes from the LH front.I dont think its a fuel pump,but the noise is similar.
    Try it without the scanner attached,it may be stopping the ECUs from shutting down.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Feb 2009
    I don't think "the noise" ever lasts more than 30 secs on ours
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
