Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Hitch advice
    Tangambalanga
    Question Hitch advice
    Hi guys,
    Just wondering what hitches you use, and why you chose yours. I understand we "get what we get when we buy", but that doesn't mean it can't be changed because of preference.
    I have on my camper a Block type, name eludes me just now,, well it's late, and I've had a big day
    So research leads me to two choices predominantly.
    McHitch Trailer Couplings
    And
    HITCHMASTER? DO35 V2-I DROP ON COUPLING
    Now, I quite like the "Mchitch" unit, as for where I have to park my trailer, I have little room to get in and out of the car to line things up and hook up, so this unit you just back up, to close proximity and it locks up to the drawbar and you can then just drive out, then latch it up properly,,, all on my little lonesome. A big bonus for me.
    The DO35, one still has to get out of the car to hook it up.
    It's not stored on concrete, so manoeuvring can be a pain to line it up.
    So, check them out and tell me what you think of both of these. They are both "up" there on price, but I want the block unit I have replaced. It's a real pain in the arse on a couple of levels.
    Cheers for your advice in advance guys.
    Jan 2010
    On sebaticle with work in Penang for a bit life is good ?
    Bacchus Marsh Vic.
    I've just bought a DO35 V2 hitch , it's on the list for fitting today.
    It's getting a good wrap from those who have them and are now suppied standard by quite a few van/camper manufacturers.
    Individual parts are available for it so that is a bonus.
    My current hitch is the AT35, https://lh5.googleusercontent.com/pr...8=w400-h300-nc
    The pin is vertical and on uneven ground can take a little effort to hook up.
    On level ground it's a one person job with a bit of draw bar wabbiling.
    The Ozhitch looks the same, be it with a horizontal pin but I've not experienced it in person.
    I think Redback has got a McHitch, he may be able to supply feed back now they have had a few trips with it.
    Which ever way you go double check the bolt pattern before you purchase.
    Being a new trailer it should be a standard thing but you never do know.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Avoca Beach
    I have the older vertical version of the Mchitch and see no reason to changes to the new horizontal version.
    Hitching the vertical version is just like hitching a ball, plus adding t he pin and screwing down the top lock.
    If you have thee horizontal version you would need to b sure that the height of the trailer was correct. This is no good to me as I wind up the leg so that water will run off. In any case I think you would have to get out to set the height.
    Of course there is more room for sideways error with the horizontal version.
    But the concept of the Mchitch is good and I have been aroundOz with one, the only problem being that a bunch of clowns in Kunnunurra stripped the thread on my ball when towing my trailer , and I had to wait a while for a new one. I now carry a spare.
    Regards Philip A
    Free Again Thanks Dan
    Marcus you are such a tight arse
    We have spoken about this lots .
    Honestly stop by and ill explain and show you the Do35 in real life hell ill even hook it up if you want to realy see it in action
    I do understand this means physical exercise by getting out of your car.
    Or is all this to help your post count
    Western Victoria
    Quote Originally Posted by rangieman View Post
    I do understand this means physical exercise by geeting out of your car.
    I think you have put the lunette in the pintle there.
    Tangambalanga
    I have nothing to say to you two
    Thanks for the info you other chaps
    (And the post count goes up by 1 more )
    Oct 2011
    Fremantle WA
    Another worthy of consideration - going on my 3.5T van
    Hyland Coupling see Home
    Happy travelling
    Bacchus Marsh Vic.
    Quote Originally Posted by gavinwibrow View Post
    Happy travelling
    This hitch is popular with the "once in a blue moon" caravaner as it uses the 50mm tow ball.
    You know them, van sits in the drive for months on end and usually does the 3 week new year trip to some caravan park
    Most of their towing is to the tip with a 6X4 and they don't want to change the hitch between the two trailers.
    The big thing is to keep the screw adjustment on to the ball right so you don't get sloop and risk it jumping off.
    Cheers, Kyle
    The Good Oil.
    Tangambalanga
    Interesting boys.
    One of the "bad" possibilities pointed out to me (by Chris,,, ever the pessimist ) was the fact that the as the Mchitch "uni" wears, it will want to fall down, thus making line up and click in probably rather difficult. I have to agree with this, but I did wonder if the uni could be tightened occasionally making it stiffer. The other option is of course to use a bit of wire or something to hold it up maybe.
