The warning light shows the difference in voltage between the alternator or generator output and battery voltage reference, which comes via the ignition switch. (Is it an original generator or is it an alternator?)
If the light shows dimly when the engine is above idle, it may indicate a faulty alternator or generator, but is just as likely to be showing a wiring fault. This is most likely a high resistance somewhere in either the circuit from the B+ terminal of the alternator or generator to the battery, or in the circuit from the battery to the voltage regulator or alternator via the ignition switch. (another possibility is the earth connection between the engine and the chassis)
In several cases where I have experienced this (one of them a Series Landrover) the problem was the ignition switch itself.
					Reason: puctuation
