Results 1 to 4 of 4
Thread: 4X4 and 6X6 driveshafts
    Hay Point
    Just out of interest does anyone know if there is any difference between the front and rear (intermediate in the case of the 6X6) propeller shafts. Even though they have slightly different part numbers I have compared them side to side and can't see any difference. I have a couple of spare new ones for a 4X4 and it looks like they will end up on the 6by one day
    Cheers......Brian
    1985 110 V8 County
    Jun 2014
    Waitakere, New Zealand
    Is there a difference in the overall length with the slip yoke fully extended or compressed?
    Just chucking ideas out there...
    Sent from my Nexus 4 using AULRO mobile app
    intermediate to rear are different on a 6x6
    intermediate on a 6x6 is almost identical to the rear on a 4x4 from memory but has a different number as part of being identified under a different part stream and as a sub part of the whole rear drive shaft assembly. I'll have to check my RPS's to find out what the part numbers were
    its like the difference between the left and right window secion, same bit of glass but because of a minor difference (the side the finger hold is pushed in from and the orientation of the sliding seal) it gets a different part number.
    Hay Point
    Thanks Dave, I thought that may have been the case. They appear to be the same thing just a different part number according to my RPS for both vehicles.
    Cheers......Brian
    1985 110 V8 County
