Results 1 to 4 of 4
Thread: Suspension Calibration with Gap Tool BT
    Mar 2013
    Gymea
    Finally got around to checking the height of my suspension today and calibrating it.
    The left rear was out by 15mm to the right and the rear in general was 10mm lower than it should be.
    Well worth checking if you haven't.
    Does anyone know why the rear is lower than the front in the specs?
    I always imagine most cars to be level or just slightly higher in the rear.
    Dec 2011
    Toowoomba
    When I did mine it was way out-- up to 30mm differences.
    reset all to "level."
    No need to set higher at rear unless u like it that way a la Japanese!
    They have to set like that to compensate for loading, something RR doesnt ( if your EAS is working properly)
    NSW SW Slopes
    Front guards need more clearance for tyres when suspension is under compression and wheels are turned significantly.
    Mar 2013
    Gymea
    Thanks.
    I set it to what the gap specs are.
    Slightly lower in the rear.
    That makes sense Graeme
