Sounds like either bottom end bearing rattle or a crook injector?
Good evening, long time since I visited this forum, guess to busy fixing Landys of all sorts.
One of my customers got me this nutcase to sort out for a x-mas present
[ame]http://youtu.be/xy0fI4MZ5hA[/ame]
Anyone with the same engine noise out there
Defender 2007, stock standard, 214 000km
Oil pressure ok, crank case pressure ok, slightly more pressure in coolant system than others
Serviced regularly
Can't wait to hear what others think
Richard
 Master
						Supporter
						Master
						SupporterSounds like either bottom end bearing rattle or a crook injector?
2 problems I can see:
Steering wheel is on the wrong side.
No defender wave as you drove past.
Other than that it does sound crook
-Mitch
'El Burro' 2012 Defender 90.
I had a similar noise on an old troopy , it has spun a little end. Oil pressure was fine and apart the noise it ran fine so it is a possibility. Check the injectors though as a faulty injector can make a horrible din.
Chris
It cant be bottom end or you would have lost oil pressure by now and it would be a heavier knock. I would be checking injectors first, I have not worked on a Puma yet but MANY other diesels. If possible disconnect one injector at a time see it the noise goes away. If injectors are fine I would be doing a compression test just to eliminate cracked pistons or dropped valves. If all good ie not injector and compression good it has to be a little end or something deeper in, cant think what else it could be though..
Chris
It's a bit hard to tell by listening to the video. Is it definitely a mechanical knock? Could it be as simple as a loose exhaust manifold both choofing and rattling?
 OldBushie
						OldBushie
						I doesn't sound like bearing knock to me but it's hard to tell,sounds more like an exhaust problem but hard to know. Pat
So, is the noise there at idle?
If not, can you duplicate the noise whilst stationary?
An old piece of garden hose, (stethoscope) in an ear the other end against the cylinder head then down to the engine block may assist in location if you can duplicate the noise whilst stationary.
Figure the injector noise would show up more at the top end than a dudgeon (small end).
It may help
Mike
