Results 1 to 10 of 21
Thread: Converting 93 LSE from Abs to 94 Disco non Abs
    Oct 2014
    So ditching Abs and traction control from the LSE back to a normal brake booster and master from non Abs disco.
    Ran into one problem Donor disco only has single brakelines.
    Back to drawing board
    1976 LR 90 Hybrid GONE
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1980'RRC Build in progress GOING
    Disco wrecking 93 & 94
    1993 RRC LSE
    Mar 2015
    Central Victoria
    ABS conversion
    Don't despair, I've had the same thing done. remove the spacer plate from the RRC calipers, split the D1calipers and insert it . You've now got a caliper with single lines but wide enough to use with the RRC ventilated discs not the solid disc of the D1.
    Like me , you're only doing this to a vehicle you use around the farm. Engineers struggle with up people like us reinventing the parts bin shuffle that occurred on the LR production line . When it worked I was stunned that everything was interchangeable . Stupid me , I shouldn't have been.
    You're welcome to come and have a look if that helps.
    Justin
    Oct 2014
    Thanks will do that was thinking of going that way.
    Thinking too hard on it last night.
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
    May 2006
    Woolgoolga
    Just get defender calipers jason, thats all i did and got it past the engineer.
    Feb 2013
    Ballarat,Vic,Aus
    Quote Originally Posted by Vern View Post
    Why would you engineer anything Just take it in for a roadworthy if required.... Don't say "boo" to anyone. They measure the rotor thickness, check the pads and lines and tick it off.
    KISS guys
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    May 2006
    Woolgoolga
    Ah because of engine and geabox conversion, bodylift, 33's, brake upgrade etc..and so i could get it registered legally so i feel more comfortable when driving around with my family!
    Thats why i had it engineered!
    Kiss
    Feb 2013
    Ballarat,Vic,Aus
    Kiss
    350 Chev ?
    Proper cars--
    Modern Junk:
    May 2006
    Woolgoolga
    Isuzu
    Feb 2013
    Ballarat,Vic,Aus
    Hmm... yeah probably. If it was a disco motor I'd probably try registering it not saying anything. It could be it would slip through given it *is* a land rover engine in a land rover
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    Oct 2014
    Sorted, Discovery Calipers with the spacers from the vented RRC to start. Perhaps Defender Calipers if required.
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
