Results 1 to 10 of 17
Thread: RRS TDV8 Front Noise - Chirp/squeal/Rattle
    Golden Beach, QLD 4551
    Hi All,
    I have a TDV8. 2008. Couple of days ago it start chirping/rattle/squeal type noise form the front Drivers side. (O/S/F).
    Appreciate advise.
    Thank you
    Chilly
    NSW SW Slopes
    My first check would be for a failing/seizing serpentine belt tensioner or idler pulley, with the squealing indicating that immediate action is required.
    It happens when I go over bumps or uneven surfaces.
    NSW SW Slopes
    Ah, so not from the engine - probably not so urgent. Could be worn roll bar bushes but have you checked the wheel nuts?
    Could be wheel bearings, could be lower control arm bushes.
    NSW SW Slopes
    I've never known a failing bearing to not howl louder and louder as they deteriorate and always sound worse when on the outside when cornering. However the chirping/squealing suggests a rotating part or at least metal on metal.
    Feb 2009
    Quote Originally Posted by Chilly View Post
    Hi All,
    Appreciate advise.
    Thank you
    Chilly
    Not something simple like the brake rotor shield catching? That's a pretty awful noise
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    That's what confuses me....does not sound like a bearing....quiet the rest of the time. Reminds me a bit of a prop uj.....so poss cv joint?
    What about the brakes...looking the pads are low....could something of fallen off....cannot stop noise by apply brake.
    NSW SW Slopes
    Quote Originally Posted by Stuart02 View Post
    A stone caught between the shield and rotor? However I'd expect to always hear it, not just on bumps.
    Maybe time to pull the wheel off and have a peek,
    Hi Graeme
    My thoughts too. Just waiting for pads.
    Thanks for thoughts
