Results 1 to 10 of 12
Thread: Rusted tailgate straps
    Brisbane, Queensland
    Today's job was to replace the straps for the lower tailgate, which were both very rusted and one recently broke. I sourced a pair of straps from Austral LR Brisbane whose pick up price was about $52each, which is the same as eBay prices including delivery. The left and right strap has an identical part no of LR038051.
    Removing the bolts for the old straps required T45 bit, the new part had 13mm bolt head. A very easy job. I coated the new part with lanolin to reduce the risk of rust. Here's some pics. image-1884337890.jpg
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    REMLR # 137
    REMLR # 137
    Aug 2010
    Sunbury, VIC
    I probably need to check mine if this is a common fault. Do you live near the ocean or is this something that happens to all of these over time?
    Gav
    It's very easy to push the cap aside to look. Also I would take the opportunity to spray some protection in there.
    I think it occurs as water drains down there. I live on the coast, but have only owned it for a year.
    It's a common problem in the uk by the looks.
    REMLR # 137
    Mar 2013
    Gymea
    I just replaced one of mine only last week.
    I also sprayed it with lanolin spray.
    Great minds think alike!!!
    Quote Originally Posted by Blade74 View Post
    I just replaced one of mine only last week. I also sprayed it with lanolin spray. Great minds think alike!!!
    Did the replaced strap fail? What's the other strap like?
    REMLR # 137
    Mar 2013
    Gymea
    No it hadn't failed but I figure it would fail sometime in the next year.
    The other one had some light surface rust. I've sprayed it with lanolin and will keep an eye on it.
    Mar 2013
    Gymea
    That's the one I removed. I couldn't even pull the rubber boot all the way back.
