What brand are they?
That said, I highly recommend not using cross drilled rotors due to cracking despite these cracking in a different location.
 Fossicker
						Fossicker
						Hi ,
Pulled the rear discs off to service the epb and found one disc has three cracks inside of the park brake drum. So would like to know the best suitable discs to buy and where to source them . Will need to be delivered to Tannum Sands. Any one else had this happen?.
Slunnie
It's possible that they could be dragging if not adjusted right, but on a D3 if you drive off the park brake automatically disengages, if it doesn't because it's stuck on as I have had happen then it really makes a horrible racket.
I only ever use OEM discs when they need replacing even if they cost heaps more than the aftermarket items.
Terry
D1 V8 (Gone)D2a HSE V8 (Gone)D3 HSE TDV6 (Unfortunately Gone)D4 V8
Worth while doing a search as there has been a few threads on this. Having said that I got Brembo rotors and pads from buycarparts.co.uk delivered to Perth for around $500.
Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
 Fossicker
						Fossicker
						Just ordered dba discs and bendex pads from sparesbox $375 del.
Howie that seems like a great price. Was that pads and rotors for all four corners?
 Fossicker
						Fossicker
						Hi
Dagilmo no just the rears heavy duty slotted .
