Results 1 to 6 of 6
Thread: After market external thermometer
    Lebanon
    I purchased an after market external thermometer, I have no idea where the temperature sensor should be placed.
    Someone suggested to install it behind the front light. Will it get heat from the light when turned on?
    Where is the best place to install it?
    Geelong, VIC
    I'd think engine bay heat rather than heat from the headlight would be the issue there. Some rangies have them behind the radiator grille. Plenty of fresh airflow while you are moving.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Adelaide Hills
    Hi
    I use an Engle fridge temperature sensor with a wired probe.
    I have fitted the probe in the Snorkel, going in near the top at the back, where the head joins on.
    I tried lots of places, this seems the most accurate.
    May 2002
    Heathcote (in "The Shire")
    I keep my sensor in the console and throw it on the mudguard for an official temp.
    Martyn.
    Lebanon
    Quote Originally Posted by steveG View Post
    Steve
    Doesn't this create a false reading due to the windchill effect ?
    Quote Originally Posted by lebanon View Post
    No.
    Wind-chill or windchill, (popularly wind chill factor) is the perceived decrease in air temperature felt by the body on exposed skin due to the flow of air. (My emphasis.)
    It doesn't change the actual temperature.
