Results 1 to 10 of 33
Thread: How to fit USB Plug on Puma Dash
    Mar 2010
    QLD
    G'day all,
    I'm away from my vehicle at the moment and can't check this for myself, so I'm hoping one of you guys could help.
    I'm thinking of fitting a USB charging socket on the dash of my Puma inside the recess between the air vents. I'm thinking of putting it on the vertical section at the front if it will fit in order to keep it as dust free as possible.
    Do you think it would fit? Failing that I'd just put it on the wider section facing upwards instead.
    NSW far north coast
    Does it have a conventional cigarette lighter ?
    If so Narva make a twin USB panel mount socket that you can remove the panel and the now round USB socket is pretty close to the same size as a normal cigarette lighter.
    Remove the cig lighter from the dash, push the USB socket in and tighten the retaining ring behind and connect the wires.
    It also sports a rubber dust cover.
    I did this a few weeks ago in the Tdi.
    Mar 2010
    QLD
    Cheers Rick,
    It does, but not in that location. That sounds like a great piece of kit though.
    X marks the spot in the attached picture, showing where I want to put a socket to power my phone.
    Jun 2007
    Margaret River
    A different location, in the glove box
    I used a Blue Sea systems PN 1016
    http://www.aulro.com/afvb/90-110-130...sb-socket.html
    Normanhurst, NSW
    Fairly limited space where you want it. Could you use one of these?
    Roger
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    I have a a usb socket under each sine of the dash in the shelf area, and one in the mirror position of the cigarette lighter socket. Also a usb extention cable up to the windscreen for phones or gps stuff.
    Mar 2010
    QLD
    Cheers guys.
    XTreme, you've inspired me to make my own. Is it just a +ve and -ve to connect?
    If I can get my hands on something like these (maybe a right angled connector), and neatly apply a judicious amount of epoxy, I think I'll be right.
    Normanhurst, NSW
    You need the electronics to reduce the 12v to 5v and (I think) to limit the current. That;s what the black box in my photos does and it appears that the same may happen in the units that you have posted pictures of. Do you have a link to a website where the ones you have posted are available? IMHO they look neater than the round one that have currently fitted to my Td5 Defender.
    Roger
    Mar 2010
    QLD
    I couldn't remember the search terms I used so I just did an image search and came up with these:
    https://www.google.com/search'tbs=sbi:AMhZZitvYAy5OMZfR8CEPu8LVPApzAsf0ND A_1XkRJJg3zjKTr5N_1sS7lzfJg1THgilwoIFmro_1d-Na5i57d_1EuAYDbkPwon1QAOg1WE_1ld4o4xdBSHRGpV3kk0DX kBPBZnGmpF48RaSQAm39jMQpBHwZ81sq5T0kQC-ljSmqgXPOJ2zwDoEwhHaMZgjswZdYPwd4ifOHezLySSI0JIz8F 6cWgNnBDo3aacY3WSFFhXtVoJI1KruH5gt8kG8qfODTtyXQLQg Skc5ZEw06_11BXDGBxk-issRMCu9lewdlKHEMkeLygPTzeBGQ93V6VQj7gXgOHClYCQ7UI TPGoPWvMkFd_1f1wGJZqkem3bV4PlgM4PvmJYQ3T8ju5c1qRg4 SxodFP668EX0ANMhK3pnxAL83OyolbDWle3PHoH95aXSInY_1X 9NoLBmjAjZCdwBGFtvfST3xFlTC69MpaVHZROdRt_1iP0uLsHf hgMepe5ZCQGWk7rIrv4XK5ZtXMQgY5L9-HB6mECX-WvNHdJFNEzn3uYB5DHkecS09ifY-UbrTkL7NUsZFJBlfmZsUdVaJGz8pqbJzA2qshAQeK6y9L2gdn0 Zgje2OBlM2mApMRPYX3SEmcUyjp3GysM7cdG9PQD91oIYsU-Q_1jfPmdHIsDD_1mUxyPgQN0-55l-ou4-vhEnLzc3LXGAE7Dlk_1MT5JexGputImYyaxyvcoVwp70S0uIYS _1yEf13p_1RPAPBzFdV4rLwo8IOlYmIf4r-UPSsFoFXqV2W7bEjRiWZzoZ5nUo0yo_1M6fNVJgx5eurisZ7W1 K3ytioQkx_1QKNGNZ58E38K_15FYNKQR_1Vn7tq-nVC2P9t-6_15lFlZlfUyHMekyl_1UdvPo-uR7PUBKOgAllBbOzbhFhehKTOFsidS6oG1UXVf-2u8bxIALsUgdHJAYpxWOZemTjroJw0JmUG-ZZ9XJTl2ktPUL0xULoJFSaWUtDecVIt-HhoPs2xG5bNQAVnKHzcqNCPdTv4vAUUXpnewzl_1Htgq0MxUVI 0pcOVLk35S4QInOqX5rVRrs9uE5y3Uh_13mmaQWuQIeK2bHGpJ yNbmNeilrMrjk4zbdPd25_1WGaVfHY1FWGuEYZ5sVZMMc5Awsq dq6CxBVHARQOYoakCrKXUbbXjhi80Uh0gOk34gU5t3LccXSUIV Tx5FSQWg5av7CCbWjRFRF1pAZFmeoplKUAS9rId4ezqnUx5kiG wha0aVrP_1DgFyZ2HdJwIAbuPEVPK1LwzBCjaU3E3uI2KpevLt nKrbjUt--_1my2SiMv13bNjr9zbPrW4fuvhJpNSE-hNERlqgZp-JrYD6eB2udEZxfaIaJmXYWDXW6e1IVs4A3KbuglOJiLaMy4-2Hknzoh3oCTDatB_1ICTb-_19mVIrBaVGdmdWv-lkWyQsa9K_12-U614ygmiZBEbwslrUUpibqpfFqor-96K7k2GALrznm6jg5Jm_1fV0pkx4FIeyN9hX0LdTgPccpfgT1X UA&hl=en
    and
    https://www.google.com/search'tbs=sbi:AMhZZisvdVLxDrnEcKSXG6BE2GJ5GMMF1KA SOBMNAgzFBLBVxnpOL4QkdeXw3ai2Lk7dj_1qeHR-Kq-agzItNswGxxVqz_11Sp8UtT1U8SamUVUDBbY495A_1ynmPGHgt QR1IDV8GdWGeHvRGhLlHhF5ajjw7ONXMZLBffCYLBPmC1pBz4V EQno4EzCk111-_1sbTn8sEI0rRQ51JRtCBDfKg4IrHBIe3yL3yBYUqb_1zUblAJ czuT3cy62kNCr6rRdSMW1CuEG2As4jRZ2Y4vGevxQMLa76jic6 N5Mwt8-GJldLJzBevz9P04AYUMKxpqFUpDiVOUN6p38XprtFcPOsfvXBl AxBaJPEOtfVlJJeMUV50_1W3i8DJ4HP9F98-6iU8R_1mXs7OssIztTP_138Ra3d-AEbsdyuxaSO_1mAC3mLDgkpiVXMbl6qc8xsN5BTSoqKChNDJ_1 RkWA3HjxPtPcR0rGj6Zx4C7dV61IyABERSJ9LL4ZAbwxU01uYy YQ1u-3JRCekP2IwdJu7Z06fiXlNNenPZaqbcLLYUMTb1LxHRbN7j77A IOOvHMRIeII1q_1hbk3iTjuOLzQT7Jdaiyt6BKO0SsRZST2fPi lAloQ_1bcZJcjsaZgVRnS8k2l3v9rUKxWQ226m8NbNS0eDXK5V 1gpzRwsQJcqsUYiUYwDatH0Qu_1GzyYgbjqrGIuLNIs0sci982 J5TLFYV-mFnRqh1lgei22CMHpM2hT7mznmuCj-8HO_1dldFupzW8JRFOVF0-akVhuzbbI_15Gr1u9nEKpzY5E8JZ6XY5NiEaECw1hdoyYPaKrj l4hRSA2CLPGz-1Dmy1onecjx0TnSh-AlK_1SXegA8HxyDnpZQwwF-mQiYa4L9q2nnBqNQA6UTr9fFEtGPE39YZgs6yk5w9syVK1xA3V a1ML0c4m1p0yfN_1BWB40vxiPmA_184gKZ9mJujL2D2bW7XPgV JjkdkYlcWCLqKJB6Gc3vWYscu0tLA1QNu5qsKIswZbgEhzFyfw E2BPVO5mluf9sG315UvG4plODgcCFUd8GehfUvpm875vDR2o0W IMXfgzQ2LvgFVEtpG6S_1ON3lB10TkgeRlQ8KPY9OY2Cz-yR3lW3FieD5JqbdhmgPtCLimhghfeo8rUljObnNiftxeIt9Owr vxtS_1-RmF4D102zsFaBcicMJkbWOlQvZ4RGfCNNt0vRAastgetfzQje0 buPjPRm59EeLfIIE9L4yXwUBCejbnwhzC01scHQiRU56LQIbQp lzVBU3gysuuZggfLcfZX9Z1KaFb2S69pF9gFaZukH8PdDy58XP moLrg1DNSDv4CQE6KqwPBEZhIJEbg7AvY4AgtZzBMUPDAdg5Mj T1qBsca3V-y4JfLmIPgJrCS6pvowZVr09x-zSmjpsrZya4nO_1wfLPY02X_1CBZm8ba5QjZctKYsTfFm8l-WqanNa1Gkpf-NXchezmuOCO37oIj-fQIwiKwbH4GwBus3T2LjJEQydrQaBYl2764zetVOlVqxDu8dqI h2nLS-zXTZKrkqmqLzrokeyisSJZL9xmWIY1jUJlT0T-YMiFSUrg1qrHVyfrpLJrhXFs7MVp_1q5luRc6sEFKMILo&hl=e n
    After more browsing I think I might try to find a simple right angled f-m adapter and reroute the USB from my stereo's head unit. Should save a lot of heartache with the running of wires. And I think I'll fit it on the right-hand side on the vertical piece running fore/aft.
    alien's Avatar
    alien is offline A Keeper of the TGO Silver Subscriber
    Bacchus Marsh Vic.
    The preferred spot as marked in the photo is not going to be easy.
    The two air vent tubes reside below.
    I want to investigate putting a usb outlet below the clock.
    It would be vertically mounted to the side of the hazard switch if it is possible.
    I have a double unit through the dash near the passenger grab handle.
    The off the shelf usb units I have bought all have lights in them so glow 24/7 with power.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
