use a vac brake bleeder to pull out everything you can and refill with fresh fluid then repeat the process until the oil stops drastically changing colour
Has anyone changed there power steering fluid?
How easy/hard is it to do.
Checked mine the other day and its not a nice colour,would like to change it.
Sent from my SM-G900I using AULRO mobile app
2014 Freelander SE TD4
2003 Range Rover TD6
92 disco tdi manual sold
95 disco tdi auto gone
just pull off the low pressure line off the power steering pump, its slightly more messy but does a better job.
When empty, with the engine off, turn the steering left to right a few times, then refill.
Thanks guys
I undo the banjo off the steering rack, gravity lets it run out. Less mess than removing hose from the top and no need to run the pump.
That sounds better yet Harlie, thanks..
I be doing it next week.
Is there special Land Rover spec fluid?
What do you guys use.
Yes, there is. I posted about it either in December or January. superCrap had it in Penrite - about $28/litre.
Here we are: Power Steering Fluid
