Page 1 of 9 123 ... LastLast
Results 1 to 10 of 88
Thread: 300 TDi crank pulley bolt....
    Sep 2010
    The Hills.
    152.79 MB
    I have been trying most of today to crack the front pulley bolt. My rattle gun, or more likely the compressor, won't cut it. I've tried the breaker bar/starter motor trick, and I've locked it in gear and used a long breaker with a pipe on it to give me about a 1200 mm pull. No way. And, yes Dave, I used a heat gun. So, a bigger compressor and rattle gun, which I can't afford, or? I've considered raising the front of the car and setting the breaker bar on the ground and then dropping the car. Other than that I'm stumped. Any ideas would be most welcome.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2010
    The Hills.
    152.79 MB
    I have made up a locking pin for the flywheel so I can do the belt, but I reckon the bolt is so tight i might break the locking pin.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Perth, WA
    I got the crank pulley bolt on my neighbors RRC undone by heating it with a MAP Gas torch, then spraying it while hot with inox, (repeated about 5x), eventually it let go. Keep a fire extinguisher handy.
    Good luck,
    Tim
    Sep 2010
    The Hills.
    152.79 MB
    Ok Tim. I have a torch, and I guess I don't have to worry about the seal....
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    Is anybody friends with Arnold Schwarzenegger?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by TimNZ View Post
    Good luck,
    Tim
    Err, I take it I'm heating the pulley, not the bolt?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Crafers West South Australia
    Quote Originally Posted by johntins View Post
    On an auto you remove the starter motor and engage a socket on one of the torque converter bolts that passes the little cut out behind the starter. A 3/8" deep socket seems to fit best. On a manual you put it in 4th gear high range CDL on and apply the hand brake firmly.
    It's the bolt you're trying to expand, not the pulley.
    NSW far north coast
    I made a crank locking tool that bolts to the pulley and wedge that against the chassis rail, then use a 5' length of water pipe on a 3/4" drive breaker bar.
    Can't find the damn photo of it.
    Sep 2010
    The Hills.
    152.79 MB
    Pretty much as I have done. It's a manual BTW.
    That's confusing. Surely expanding the bolt will make it tighter, or am I missing something? Does expanding the bolt crack the coefficient they have somehow?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    NSW far north coast
    If it's Loctited it kills the loctite and if it's rust or corrosion holding it it breaks that bind as it cools.
