Results 1 to 4 of 4
Thread: What primer to use?
    What primer to use?
    Ugh I know.
    I DID search this but there were so many hits that I'm still confused.
    My situation is that I want to repaint the interior surfaces of my tub. Most of the paint is sound (but I want to change the colour). some areas required repair and are bare metal.
    I know that etch primer is desirable on aluminium surfaces but understand that it damages painted surfaces - so can/should I use it?
    What about other primers (under an acrylic lacquer primer/ topcoat) - Is it better to use a zinc primer (which I understand will stick to the aluminium) or something else?
    Russ
    Nov 2015
    Tamworth
    have you looked at raptor liner? they have a 1k etch in a aerosol, for the bare metal, then you top coat it all with the raptor. Raptor shoots from a schutz gun, or you can roll or brush it. Also has a tintable, so you can get the colour you want.
    Under raptor, their etch primer on bare metal is fine.
    General rule is etch is only for bare metal, but there are some combination etch primers that can go over anything.
    Be careful with acrylic primers, they will not sit well under products like raptor liner.
    Thanks - Ill look raptor up
    Feb 2013
    Ballarat,Vic,Aus
    It it being done properly in a booth? If so a quality epoxy urethane primer will go over the bare metal and keyed paint. The seppos swear by it ( I used to read quite a bit over here ).
    Index page • How to Paint Your Own Car, Auto Body Discussion Forum & Videos • AutoBody101.com
    If your doing this yourself, I have found that Hi-Chem super etch epoxy primer is nothing short of brilliant. I painted my old Citroen CX about 12years ago with acrylic laquer ... the paint has been fubar for quite a few years now ( acrylic laquer/dulon doesn't last for **** sadly). However all the stainless door trims I first coated with the above primer (from a rattlecan) then some GMH black (ie: satin black). I expected the stainless to peal within a couple of months. Fast forward 12years. And there the most unmarked paint on the car. Absolutely amazing!
    Super Etch Primer Grey 1L Epoxy Etch Primer MILD Steel Galvanised Steel Hichem M in VIC | eBay
    Super Etch Primer Grey 400ml Aerosol Galvanised Steel Hichem Motospray in VIC | eBay
    It really does stick like **** to a blanket
    seeya,
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
