Results 1 to 10 of 14
Thread: Aircon query
    PeteB Guest
    Aircon query
    Hi All
    Just bought a discovery 4 3.0 tdv6 3.00 2011 model with 155k on the clock and noticed the aircon takes 3-4 minutes to start working and then is fine , can someone let me know if that is normal as I have asked the dealer to check as have 3 months warranty and wanted to make sure all ok . My mate has a 2015 model and recons that is normal ?
    May 2010
    Brisbane, QLD, Australia
    Quote Originally Posted by PeteB View Post
    Hi All
    Nope. Not normal.
    I had a MY10 and now own an MY13 .... aircon started within seconds of start-up in both cars.
    Dec 2011
    Forrestfield WA
    Certainly not normal but mine has started doing the same thing since they did the inlet manifolds. Seems a common issue with L322's as well and I had the same thing on my VW Multivan at 100,000km. Once it goes it is fine but it is a bit hot while waiting for it to start. I will get mine fixed, probably a new compressor, since fixing the offending valve doesn't always last long without a new compressor from what I have read. It is related to the always on compressor type air con that these cars use.
    Maybe Graeme can explain what is going on???
    Bob
    Feb 2009
    Do you mean for the cold air to come through or for the fan to fire up at all? Our 2010 RRS takes a minute or so for the cold air to come arrive
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    My MY06 is often that - up to 6 minutes for truly cold air to exit the vents...
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    PeteB Guest
    Aircon
    Fan kicks in straight away but took 20 mins to get cold whilst car was stationary
    Mar 2015
    Engadine
    Quote Originally Posted by Narangga View Post
    I always thought my MY05 took a while to get cold. The added bonus of getting a new engine is that I get my AC re-gassed (I feel compelled to find a positive in anything to do with this engine replacement!!). It will be interesting to see if it performs any better.
    Oztourer
    MY05 TDV6 HSE, Buckingham Blue
    Front Runner Slimline II roofrack and rear ladder, Safari Snorkle, Mitch Hitch, Traxide D3-DU, Bushman Fridge, Icom IC-440N UHF, Hema HN7, Tyredog TPMS, GVIF and reversing camera
    Dec 2011
    Forrestfield WA
    I just got mine regassed and inspected to see why it was taking a long time to start. They said it was perfect and then when I picked it up while it was 42 degrees outside, the A/C wouldn't start cooling for over 5 minutes, just blew hot air flat out. It finally started and then worked fine.
    Its been good for a week and then on the weekend wouldn't start cooling again for over 3 minutes. After that, fine again.
    Bob
    Feb 2009
    Yeah that ain't right!
    Williams West Aust
    Mine hasnt missed a beat,too new.Always cold straight away.
    I have never turned the air off,even in winter,just pic a temp and fan speed.
    I recall reading the aircon pump in these are constant flow so if its running may as well have it on.
    I could be wrong,happy to be corrected.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
