Results 1 to 10 of 17
Thread: Which carby is best for the 2.25 petrol engine?
    Hi all
    I removed the carby from my 64 today to discover it is a stomberg. The reason I removed it was I could not get the choke flap to close so I took it off for a closer inspection.
    The choke would not close due to a rusty/seized mechanism at the base of the carby.
    I am assuming this is not the original carby from this motor and it has a lot of rust on some parts so I don't think it is worth spending any money on it.
    I have done a quick search and see I have three options:
    1. Solex copy
    2. Zenith copy
    3. Weber
    What is everyone's opinion here, or is there another alternative?
    Thanks heaps
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    schuy1 Guest
    How long is a piece of string? each carby has a following in regards to best. IMHO if it came with a solex, thats the best, If it was a zenith go for it. It really comes down to the jetting for a particular size engine, and each of those, if it came of a rover will be jetted for the basic performance needs of the motor. Where aftermarket carbs fall down is when the motor is called upon to do the offroad work, that is where a factory setup is best.
    Cheers Scott
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    you want torque (solex), revs and maybe a little better economy but that was not my personal experience (zenith) or more vaporisation that you need (weber) tho they are significantly better if you have headers.
    no doubt a heap will beg to differ but it has been my experience..
    i run a solex ....
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    the zenith is the simplest and easiest to tune and field if its in good nick
    the solex gives a wider rev range and responds better but is harder to setup and tune than the zenith
    theres a bunch of webbers you can use, a single cd175 is nice, theres a handful of strombergs too but these need custom linkages and fittings.
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    My experience is that there is little to choose between the Zenith and the Solex in good condition.
    The Zenith is easier to understand, and hence to rectify any problems that arise. Possibly easier to get parts for.
    These are the only two that have been fitted to Landrover fours in Australia, and a problem with any others is both ensuring that the jets etc are appropriate and getting it set up and also troubleshooting any problems. OK if you are or have access to an expert on carburettors, but for most there are advantages in remaining standard.
    Thanks for all your replies.
    I have never heard of Zenith before and I have had a lot of experience with Solex on my 1972 Peugeot 504.
    Can either of these be set up using the standard Landrover accelerator linkage or do they need a cable?
    Andrew
    Sandgate, Brisbane
    I put a Zenith copy on DaOot.
    It was a straight install with the linkages all lining up perfectly.
    Carby worked a treat.
    JDNSW's Avatar
    Both use the standard linkage. Note that the Zenith needs an adapter (554175) below it that twists the carburettor 90 degrees relative to the mounting bolts. The throttle shaft on the Solex is parallel to the mounting holes, where the Zenith has the two at right angles.
    Late Series 3 used an accelerator cable I believe.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    The zenith will last much longer using a cable I am lead to believe
    Nov 2011
    Why would a cable make a difference to how long a Zenith lasts?
    Wouldn't both would pull on the same arm?
