Results 1 to 2 of 2
Thread: aircon issues
    Mar 2009
    maryborough qld
    aircon issues
    My td5 130's air con stops every so often for no apparent reason.The fan just stops,fuses ok,wiggle wires,nothing.Day or so later all good again.Compressor not running when it stops working.Low on gas maybe?
    Oct 2014
    Fremantle
    has it been hot? maybe its cutting out on High disch press, check your condenser is clean.
    Could also have too much gas causing HP cut out.
    When the weather gets hot, comp will run on higher HP and to keep it running good you need a clean condenser to effectively bring the hp down
