Results 1 to 10 of 24
Thread: D2 Vibration Sound - Not Prop Shaft
    Jun 2011
    Victoria - Pakenham
    I have a strange vibration sound when driving and the RPM about 2500. If i power on hard i don't hear the vibration.
    It sounds like a loose baffle inside a muffler, but I've removed my centre muffler and CAT and it is still there.
    It almost sounds like it is coming from the engine bay, but that could be misleading as i'm not sure where it is coming from, it could potentially be under the dash.
    I've got no idea what it could be. Any ideas?
    P.S I've removed the disc brake guards on the wheels. It is not them.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Didn't you replace a front diff recently? could be coming from something there?
    Williams West Aust
    Check the turbo heat shield,had a similar noise on my D2.Rear lower bolt rusted out
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jun 2011
    Victoria - Pakenham
    Rear diff but not that kind of serious noise anyway.
    Jun 2011
    Victoria - Pakenham
    Andrew
    Might be it.
    Nov 2014
    Nirvana near Albany W.A.
    Could be a bit high in the rev range but have you eliminated the handbrake shoe rattle, gently ease on the handbrake and see if it goes away
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by Jazzman View Post
    Might be it.
    remove it and eliminate that for sure.
    Jun 2013
    Augusta WA
    Intermediate silencer heat shield?
    Jul 2014
    PERTH, WA
    Vibration Noise
    Hi Jazzman,
    I had something similar with a non-LR vehicle, and concluded that it was exactly what you said - a loose or corroded muffler baffle.
    It actually turned out to be due to a worn / broken engine mount.
    Sounding as though it is coming from the engine bay fits with that possibility.
    Mine was most noticeable when decelerating - fits with your observation about not being evident when you power on hard.
    May be worth a check.
    AndrewMilne
    Bairnsdale enjoying the rural view no rooftops to see here
    If it's a td5 check the vibration damper on the transfer case and also the heat shields on the mounts
    Sent from my SM-G900I using AULRO mobile app
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
