Results 1 to 10 of 12
Thread: Belt tensioner bearing replacement
    mattg Guest
    Hi guys. I have the bearing squeak I read ages ago that we can just replace the tensioner bearing but I can't find the thread. Anyone got the bearing part number? Also is this false economy as the spring has 228,000km on it as well.
    Cheers Matt
    May 2003
    On The Road
    I just searched for "tensioner" using the old advanced search function and came up with 290 odd results,,
    When I replaced the whole arm on my green one the ribs were showing through the pulley!
    mattg Guest
    I searched for 45 minutes through the results and can't find the part number.
    mattg Guest
    Pulley is in good condition
    Bacchus Marsh Vic.
    My recommendation is to always replace the full unit.
    I've never had success just doing the bearing on these adjusters(or the idler).
    Given the Km done the pivot and spring will have wear also.
    Keep the old unit(s) with the old belt as spares in the back.
    If it's non ACE consider doing the idler pully while your going, it's done the same work.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    St Helena,Melbourne
    4.28 MB
    I'm sure they are the same as the D1 tensioner, remove pulley and drill or grind a small notch in the gap of the snap ring down to the bottom of the ring recess.
    Lever old ring out, take pulley and find a circlip that fits.
    Bearing will be a 6203, buy Jap if possible.
    Fit new bearing along with circlip, jobs done.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    schuy1 Guest
    The tensioner pulley/bearing arrangement on a TD5 is not the same as a Tdi. The bearing is not replaceable on its own. The pulley is a 2 piece pressed metal arrangement riveted together with the bearing . To replace the bearing you would have to drill the rivets out to seperate the pulley. So it is a total replace job I am afraid.
    Cheers Scott
    Aug 2015
    Notting Hill
    It can be done.
    Hi Folks, I have replaced the bearings in both the tensioner and idler (non ACE car). The tensioner was not hard. Drill out rivets and separate the 2 halves of the pulley. I don't remember the part number of the bearing but I sourced it from Bearing Services for affordable cost. To reassemble I used Loctite on the mating surfaces of the halves and joined them with mushroom headed 1/4 inch screws and flat square nuts. Careful which way around you fit them due to clearance on the housing at the rear and mounting plate on the front. Use Loctite on the threads also. Carefully measure the length of the screws for minimal protrusion through the nuts. When nuts fully tightened use a centre punch to pop the centre of the end of the screw which just protrudes from the nut to keep it all from coming apart. Let Loctite cure prior to refitting.
    The idler on the other hand is a cast pulley and the bearing is just pressed into it. Remove it, press in a new one and refit. I have a nagging feeling there was a circlip to retain bearing but am not sure. The bearing was also sourced from Bearing Services.
    Car has done 40,000 km since the repair and now has 275,000 on clock.
    Hope this helps, GIL
    Aug 2011
    Coober Pedy, South Australia
    The bearing numbers are 6203 and 6303. I've successfully replaced both tensioner and idler bearings twice. You need to drill the rivets, carefully separate the two pulley halves, knock out the bearing then gently press the new bearing and two halves back together again. I used either M5 or M6 bolt with nylock lock nut, in place of the rivets, however I would suggest using a 262 or similar Loctite as well. I'm pretty sure I had to shorten the bolts down so it wouldn't interfere with the arm or housing behind?? Also I recall the other pulley had some little stakes retaining the bearing. Once you've pressed the old bearing out/new one in, you then need to restake the housing to ensure it won't move.
    My vehicle has now done 352,000 kms and with the original tensioner. However I do inspect it all regularly.
    Now having said all this, do this at your own risk. In my workshop I typically recommend replacing the whole assembly, depending on the situation. Good luck!
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by schuy1 View Post
    Cheers Scott
    Thats a shame, easy fix on a D1.
    Google images wasnt that helpful so is the pulley ribbed and not flat ?
    1974 VW Kombi bus
